Problems with ARP on 871W
jocovarr
I have an 871 set up at home with 2 VLANs, both of these vlans present a strange behavior where an user is unable to ping/contact another user on the same subnet, however if users are on different subnet it seems to work
According to the troubleshooting that I have done, the issue seems to be with the broadcast traffic, ARP request/reply do not reach another host on the same subnet (wireless to wireless or wired to wireless) however if the wireless device iniciates the connection  to wired,  it works fine.
This is a section of the config I have.
dot11 ssid office
vlan 1
authentication open eap eap_methods
authentication network-eap eap_methods
authentication key-management wpa
dot11 ssid home
vlan 2
authentication open
guest-mode
wpa-psk ascii 7 03510E5E5456711C1E5F4F
bridge irb
interface FastEthernet0
description  Corporate office
spanning-tree portfast
interface FastEthernet1
interface FastEthernet2
description home
switchport access vlan 2
no cdp enable
interface FastEthernet3
description home
no cdp enable
interface Dot11Radio0
no ip address
encryption vlan 1 mode ciphers tkip
encryption mode ciphers tkip
encryption vlan 2 mode ciphers tkip
broadcast-key vlan 1 change 50
ssid office
ssid home
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
packet retries 32
channel 2462
station-role root
rts threshold 2312
rts retries 50
antenna receive right
antenna transmit left
antenna gain 128
no cdp enable
interface Dot11Radio0.1
description office
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.2
description Home
encapsulation dot1Q 2
no cdp enable
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 spanning-disabled
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
interface Vlan1
description office
no ip address
ip nat inside
ip virtual-reassembly
load-interval 30
bridge-group 1
interface Vlan2
description Home
no ip address
bridge-group 2
I have tried to enable proxy arp on the different VLANs and BVI and different combinations but no sucess in order to get traffic across 2 wireless devices on the same subnet or a connection that is iniciated for a wired client to a wireless one.
Play with the native vlan but no luck either
Finally I tried enabling and disabling dot11 arp-cache but no luck
Any ideas?
Jorge
jocovarr
Forgot to add bvi config
interface BVI1
description office
ip address xx.yy.117.1 255.255.255.240
ip access-group FIREALL_inside_inbound_1 in
ip admission Office_access
ip nbar protocol-discovery
ip flow ingress
ip flow egress
ip inspect  one in
ip tcp adjust-mss 1260
load-interval 30
service-policy input QoS_Inband
interface BVI2
description home
ip address 10.0.2.1 255.255.255.0
ip access-group 157 in
ip flow ingress
ip flow egress
ip nat inside
ip inspect one in
no ip virtual-reassembly
ip route-cache policy
ip policy route-map ROUTEMAP_1
load-interval 30
Have you had any luck with this?  I'm having a problem with my 871 where traffic stops being fowarded, out the LAN ports fa0-3.  If I look at the arp entries, I can see them aging:
871#show arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  70.64.168.129           0   0001.5c32.e781  ARPA   FastEthernet4
Internet  70.64.168.179           -   001d.a2c2.f93d  ARPA   FastEthernet4
Internet  192.168.1.100           6   78a3.e4a1.3625  ARPA   BVI1     <--------- This device is trying to ping the router
Internet  192.168.1.113           1   78a3.e4a1.3625  ARPA   BVI1
Internet  192.168.1.114           7   7c6d.628d.73bd  ARPA   BVI1
Internet  192.168.1.115           7   9027.e4e9.390b  ARPA   BVI1
Internet  192.168.1.116          52   d023.db13.7be2  ARPA   BVI1
Internet  192.168.1.117           8   0026.08ea.628a  ARPA   BVI1
Internet  192.168.1.254           -   001e.1344.64a0  ARPA   BVI1
Even trying to send traffic to the router from a directly connected device isn't updating the arp table.  I can fix it with a shut/no shut on the port but it goes down again in a few days.  Also is it normal to see everything from BVI1, I only have one bridge group to allow traffic between the wired and wireless interfaces.
