09-22-2017 08:59 AM - edited 07-05-2021 07:41 AM
Anyone with AIR-CAP1602 experiencing problems with laptops running Windows 10?
All other type of wifi clients (smarphones, mac book, even surface with windows 10) use the network without any problem. It's only when they are connected to the 1600 AP, they are branded as being in "RUN" state by the WLC but the laptops don't have connectivity. Once they connect to any different type of APs, they are up an running.
2x 2504 with AirOS 8.2.161
They have several APs; 2700, 1700, 1600 and 1140.
-smarphones + all APs= ok
-windows surface with windows 10 + AP 1600 = ok
-windows 8.1 laptop + AP 1600 = ok
-windows 10 laptops + 1600 AP = NOK
-windows 10 laptops + any AP other than 1600 = ok
Vasco
Solved! Go to Solution.
09-20-2018 09:01 AM
09-20-2018 03:04 PM
@anumpand wrote:
My customer is on code 8.2.167.0 and he is facing same issue. What do you suggest?
Please create a new thread so we can help.
09-20-2018 03:57 PM
