02-28-2013 02:02 PM - edited 07-03-2021 11:38 PM
What can be the impact if i put a couple of projectors in my WLAN..?
The projector will be in my Global WLAN, where all the users are.. could be an impact in the network..?
Solved! Go to Solution.
02-28-2013 06:51 PM
Should not be any issue. The projectors sometimes needs to be on the same subnet because the management tool uses broadcast to be able to control it if both the projector and client is wireless.
02-28-2013 06:51 PM
