09-15-2016 02:44 PM - edited 07-05-2021 05:50 AM
Hi all,
We have setup 3 Catalyst 3650 in converged access mode.
One is the Mobility Controller and 2 are the Mobility Agent.
i have setup the Switch Peer Group and it's working well
But when i add a new WLAN on the MC it does not propagate to the
MA's.
Do i have to setup a something for this or do i need to add the new WLAN
manually on all MA's ?
Thanks for any help
09-15-2016 02:54 PM
here is my Wireless Mobility summary
Mobility Agent Summary:
Mobility Role : Mobility Agent
Wireless Management VLAN : 10
Wireless Management IP Address : 10.10.0.3
Mobility Switch Peer Group Name : SPG-C1
Multicast IP Address : 0.0.0.0
DTLS Mode : Enabled
Mobility Keepalive Interval/Count : 10/3
Mobility Control Message DSCP Value : 48
Switch Peer Group Members Configured : 2
Central Management : Disabled
Link Status is Control Link Status : Data Link Status
The status of Mobility Controller:
IP Public IP Link Status
10.10.0.2 10.10.0.2 UP : UP
Switch Peer Group members:
IP Public IP Data Link Status
10.10.0.3 10.10.0.3 N/A
10.10.0.4 10.10.0.4 UP
09-15-2016 04:34 PM
Do i have to setup a something for this or do i need to add the new WLAN manually on all MA's ?
Yes, you have to manually configure those WLAN configs on MA
Rasika
*** Pls rate all useful responses ***
09-16-2016 01:52 AM
Thanks for you answer Rasika, does this means i have to add all the VLAN also manually ?
