03-21-2013 08:11 AM - edited 07-03-2021 11:46 PM
Hi All,
I am trying to push a simple configuration to WLC using Prime Infrastructure. But it is failing as PI doesnot have RW SNMP access.
My question is that can I use PI to push configs without using SNMP. Like do it using ftp or something.
Also do the Wired Devices also need SNMP RW access on PI's part.
All your help is appreciated.
Mukul
Solved! Go to Solution.
03-22-2013 10:58 AM
You need SNMP RW.
If you use CLI template you need ssh/telnet credentials though.
03-22-2013 10:58 AM
You need SNMP RW.
03-22-2013 11:21 AM
Thanks.
I will try that.
