Question regarding 1230 access point and YAGI antenna
jljamison
ok hopefully not to dumb a question. I read somewhere in the ordering guide for the 1230 that you need to order two antennae in addition to the base access point or access point/radio bundle
Is that true for all antenna types or just the typical dipole type. I am considering the directional YAGI antenna, part AIR-ANT2410Y-R. Do I need two of them or not?
Are these suitable for external mounting? Is it typical to mount an antenna on the exterior wall and mount the access point on the interior (such as a crawl space), assuming the installation of a lightning arrestor?
scottmac
Level 10
Level 10
You can set the AP to use one or two antennas in the interface configuration.
Dual antennas are usually used inside in "Diversity" setting: Diversity is a mechanism to reduce the effect of multipath from signals that are bounced around inside.
Diversity "listens" on one antenna, then the other, never both at the same time. They are spaced such that a flakey signal on one antenna is likely to be improved on the other.
For most external applications (like with the Yagi) you only use one antenna.
Were to mount the external antenna will depend on the range between systems, clear line-of-sight, and geography ... you put the antennas high enough to clear all interfering foliage or structures (plus some for the "fresnel zone."
The other thing to remember is "environmental events:" there are things called "Lightning arrestors" that ae NOT effective against direct or near strikes ... they;ll bleed static electricity are reduce your chances of getting hit, but if it gets hit, your system is toast.
A much better guard against internal system damage is to use a segment of fiber optic cabling between the AP/bridge and the internal LAN to electrically isolate the external systems from the internal systems.
There are a number of vendors for copper --> fiber / fiber / copper transceivers for well under US$100.00 each side.
Good Luck
Scott
