08-20-2014 08:23 AM - edited 07-05-2021 01:24 AM
Hi everybody,
Would a "AIR-CAP3702I-A-K9" be compatible with "AIR-CT2504-50-K9" regardless of the fact that WLC doesn't support 802.11ac? Would it work ok with 802.11b/g/n?
Thanks.
Solved! Go to Solution.
08-20-2014 08:29 AM
Yes it is comaptible.
But make sure that you must have WLC version 7.6.100.0 or higher.
Check the compatibility matrix:
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Dont forget to rate helpful posts
08-20-2014 08:29 AM
08-20-2014 08:39 AM
Ok thanks Sandeep!
07-30-2015 04:08 PM
This discussion has been reposted from Additional Communities to the Other Wireless - Mobility Subjects community.
