05-22-2020 04:37 PM - edited 07-05-2021 12:05 PM
I am having difficulties to upgrade IOS for Catalyst 3650 with Converged Wired plus Wireless Access via PI running 3.8 version
And these switches are listing themselves as WLC.
How do I rectify this? Need help please.
05-22-2020 05:07 PM
That is normal.
What version of IOS-XE running on your 3650? If you are using converged access wireless 16.3.x is the last code that supports that feature.
Rasika
*** Pls rate all useful responses ***
05-22-2020 05:50 PM
You are right. I have a mix of 03.06.06E, 16.3.5b and 16.6.1 the thing is we are not using these switches as converged WLC.
I wanted to upgrade to 16.09.04 and keep all 3650s the same across the network.
05-22-2020 06:06 PM - edited 05-22-2020 06:14 PM
if you are not using converged wlc, then you can upgrade your switches to 16.9.x without impacting any function.
Follow the release note upgrade instructions carefully when you do upgrade switches. Test it with one stack & make sure you verify the process and time taken for these upgrades. Then you can plan out the rest
One thing to note is beyond 16.6.x release, it uses smart licensing on these switches, instead of RTU license. Keep that mind and make sure you have your smart license portal setup.
Keep this page bookmarked as it listed recommended software releases for Cisco switch platforms
Rasika
05-22-2020 06:14 PM
Thank you so much!
But I was wondering a way to do it via PI just to avoid upgrading one by one and save time & effort.
05-22-2020 06:17 PM - edited 05-22-2020 06:26 PM
If you have done it in the past and you are comfortable with that process, you can follow it. Here is some helpful document
Here is a video demonstration of that process taken from about document.
I would always test the manual method first and make sure you know what it involves & the time taken. Then test it with Cisco prime with one stack & slowly do bulk upgrades.
Rasika
05-22-2020 06:54 PM
Thank you once again, yes use bulk upgrade via PI however these converged WLCs wont appear for selected version to upgrade. The reason is they appeared as WLC not as typical switch.
05-29-2020 03:35 AM
05-29-2020 06:09 AM
