Radius authentication issue for wifi
AsifParkar20245
multiple users are unable to connect to wifi network. Meraki dashboard shows authentication and association failures for the SSID in question. what could be the issue for 802.1x authentication with Radius?
6 Replies 6
Mark Elsen
 - Check the (radius)-logs on the Radius server (too) , what is reported for the failing authentications ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
ammahend
need more information
has this ever worked before ? when did the problem start ? what changed ?
what radius server you are using ? can you share radius logs ? when you do radius test from Meraki dashboard does it pass ?
-hope this helps-
Hi @ammahend , pls find below:
yes this has been working fine since years, the problem suddenly started last week
Windows server..from Meraki dashboard the test is successful
        >....Windows server..
 https://social.technet.microsoft.com/Forums/windows/en-US/2d5376a4-eb80-428d-b642-3e30fc6438c3/where-are-the-logs-for-nps-stored?forum=winserverNAP
 M.
       Beauty and terror
      Just keep going
       No feeling is final
if the tests are successful with the same credential as users are connecting, then we can rule out shared secret mismatch, AD issues. look at radius logs, as suggested by marce1000 below, check if there was any update pushed to clients...
-hope this helps-
bsmagulov1
