Reboot AccessPoints over WLC4404
Kevin Haag
HI,
We have two Cisco Wireless Controller 4404 with the IOS Version 7.0.220.0 and a lot of accesspoints (ca. 170). Now i wan't to reboot a group of Accesspoints where i found over a filter... Is this possible?
Or how can i reboot all the AccessPoints at the same time over the Controller Interface? Is it possible?
I only found the option in the WebGui where i can reboot 1 AccessPoint at the same time with "hardware reset"... but it would be a bit annoying to reboot it all by hand
Thank you for your reply!
Best regards
Kevin
Best regards Kevin
Scott Fella
You can run this command on the GUI: config ap reset
So what I do is put the ap names in excel and then combine the command with the name and then just cut and paste.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
5 Replies 5
Scott Fella
Scott
-Scott
Hi Scott
Thank you for your fast reply. Your hint helps me to save a lot of time ;-)
I have maked a post in my blog with an detailed description, if someone is interested in it :-)
http://blog.beroot.ch/?p=559
Best regards
Kevin
Best regards Kevin
Scott Fella
Kevin,
Glad it worked for you... I usually script a lot of this because it tends to be easy than using the GUI. I think the only thing I use the GUI for that is easier than a script is placing AP's in an ap group. But I do still script that piece. Learn some of the CLI commands and it can be fast to do many things. Also having WCS/NCS/Prime Infrastructure can help too.
-Scott
Hi Scott,
Usually i configure all Devices over the CLI. But in WLC i don't have much know how, how to configure it over the CLI ;-)
But i will learn it :-)
Best regards
Kevin
Best regards Kevin
It's takes some time to figure out what commands need to be entered first, but the commands are all listed in the reference guide. Here is one for the v7.0
http://www.cisco.com/en/US/docs/wireless/controller/7.0/command/reference/cli70commands.html
-Scott
