05-30-2016 11:06 PM - edited 07-05-2021 05:09 AM
I have a 2504 WLC running v8.0.121.0
With about 12 AIR-LAP1142N-A-K9 on v8.0.121.0
We use WPA2+PSK with AES and all that works fine.
We are experiencing some issue with roaming. Users report having to reboot there systems (because they do not know what else to do) in order to get reconnected.
I am hoping for some guidance with the Client Roaming settings and any other things we can recommend.
Thanks, in advance.
S
05-30-2016 11:24 PM
Make sure 802.11k, 802.11r and 802.11v are enabled.
It may be possible you have one problem access point, and that when users connect to it they fail. Try verifying that you can connect to each access point, and that it works.
05-30-2016 11:39 PM
I am not familiar with 802.11k, 802.11r and 802.11v but I have verified all AP's in the area in question are up and reported good in the controller
05-30-2016 11:41 PM
Follow the best practices design guide.
You didn't quite do what I said. You need to actually connect to each access point and verify you have connectivity. Checking that the controller says that each AP has connectivity is not sufficient.
05-30-2016 11:25 PM
Upgrade the firmware first to, at least, 8.0.133.0. 8.0.121.0 is extremely buggy.
05-30-2016 11:36 PM
Thanks. I am on that version at the recommendation of Cisco TAC but will upgrade on your advice.
05-30-2016 11:44 PM
05-31-2016 08:09 PM
For AireOS 8.0 customers, TAC recommends 8.0.133.0 (latest CCO release AKA 8.0MR3).
