Showing results forĀ
Search instead forĀ
Did you mean:Ā
Record Cisco 1941W EC IO using PRTG
CB90021204
Level 4
Level 4
I loaded the following MIB into PRTG 'CISCO-WAN-3G-MIB' hoping to record RSSI and ECIO values on my 3G 1941W cisco router. RSSI is now recording using 'c3g current gsm rssi' however ecio isn't recording using 'c3g current gsm ec io' or  'c3g notif ec io'.
Has anyone played around with this or got it working? I found the MIBs from the links below?
http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&step=2&submitClicked=true&mibName=CISCO-WAN-3G-MIB#dependencies
http://tools.cisco.com/ITDIT/MIBS/MainServlet?ReleaseSel=3849&PlatformSel=56&fsSel=1284
CB90021204
Level 4
Level 4
I might have answered my own question. I just added 'c3g gsm nearby cell ec io measurement' and it appears to be working now.
