Remove login for guest wireless.
richardin
Beginner
Beginner
I need to see if it is possible to remove the login and keep the password, on our guest wireless account. They want guest wireless with out a log in, just password. Not sure if I would need to delete the web login page...
Francesco Molino
VIP Mentor VIP Mentor
VIP Mentor
To do so you'll need to change the config of your wlan. Remove l3 authentication and change the l2 authentication to wpa-psk.
This is the simplest way if authentication is done on your wlc.
 if not wlc, which system is managing the authentication.
PS: Please don't forget to rate and mark as correct answer if this answered your question
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Recognize Your Peers
