10-21-2014 11:40 AM - edited 07-05-2021 01:46 AM
We are running a 7510 FlexConnect controller in an HA environment. We recently upgraded to code 7.6.130. After the upgrade, we have clients (RF handheld scanners and truck mounts) in our warehouses that are getting disconnected, pings fine then drop. It takes a reboot of the AP or device to get them connected again.
The WLAN is configured for WPA2/PSK security, the AP's are 1242's FlexConnect. We have not seen the issue on any of our 2602e AP's with WLAN's configured the same.
We rolled one location that was having issues to an older WiSM, no issues with connectivity reported.
Any ideas?
10-21-2014 12:22 PM
It sounds like a bug related to 1242 in Flexconnect with 7.6.130.0.
Reach TAC & check with them to see any known bug IDs & applicable resolution
Rasika
**** Pls rate all useful responses ****
03-18-2015 12:43 PM
did anyone have a solution to this issue?
03-18-2015 05:19 PM
No...we ended up downgrading to 7.4
03-19-2015 06:32 AM
Was that a recommendation from TAC? Did you consider going to 8.0.110.0?
03-19-2015 06:37 AM
Not a recommendation from TAC, we had success using 7.4, the higher-ups just wanted to get back to stable code as the issue was impacting our production. Didn't want to risk going to 8.
03-18-2015 12:44 PM
did you find a resolution
