06-25-2015 10:48 PM - edited 07-05-2021 03:28 AM
Greetings All!
I have a AP1142N-A-K9 that I picked up in a surplus lot and was wondering in I could use it to connect devices in a detached shop which has a switch which is connected to a Wi-Fi equipped modem with Cat 5 cabling?
The existing Network works fine, I just want to connect wireless devices in the shop which are out of range of the existing modem?
Carl
06-26-2015 12:37 AM
Yes you can do it.
first check if this AP has autonomous image or lightweight image.
check : https://rscciew.wordpress.com/2014/01/04/understand-access-point-ios-images/
how to configure a autonomous AP:
https://rscciew.wordpress.com/2014/05/24/single-ssid-configuration-on-autonomous-ap/
Don't forget to rate helpful posts
06-26-2015 04:52 AM
https://supportforums.cisco.com/document/49351/upgrade-1142-lwap-autonomous
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/15-3-3/configuration/guide/cg15-3-3.html
