Shut down LED on cisco LAP1131AG
is it possible to shut down the LED on the AP LAP1131AG?
When yes, where could I find intformations how to switch it off?
Thanks a lot.
Best regards
3 Accepted Solutions
Rob Huffman
Hall of Fame Community Legend Hall of Fame Community Legend
Hi Christian,
Scott is most correct here +5 my friend!
I'll add this just in case you actually have an Autonomous AP;
This example shows how to turn-off the 1130AG Status LED:
AP(config)# led display off
http://www.cisco.com/en/US/docs/wireless/access_point/12.4_3g_JA/command/reference/cr43main_external_docbase_0900e4b180443057_4container_external_docbase_0900e4b180480623.html#wp3339779
This should be seen in a "show run" for the AP
Cheers!
Rob
"Celebration it's around us, every nations, all around us.
Singin' forever young, singin' songs underneath that sun" - K'naan
The config t is not needed on an LWAPP AP. Everything is configured for that ap from the WLC.
-Scott
Here is the commands... you can do all or just one at a time:
(WLC) >config ap led-state disable ?
all            Applies the configuration to all connected APs.
     Enter the name of the Cisco AP.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
12 Replies 12
Scott Fella
Hall of Fame Guru Hall of Fame Guru
Hall of Fame Guru
From the CLI of the WLC issues a config ap led-state ?
-Scott
Yes I mean the LED which show the state of the AP.
No... That is the command. Config ap led-state disable. I put the question mark be cause its either the ap name then disable or disable then ap name.
-Scott
Could I do that from remote or must I connect me directly on the AP?
That must be done on the WLC when the AP has joined. You have a LAP, so that means its lightweight and requires a WLC. An AP1131AG is autonomous or stand alone.
-Scott
Rob Huffman
Hi Christian,
Cheers!
Rob
Thanks Rob... also +5 for putting the autonomous command!
Scott
-Scott
thanks for the great example, but I have now an other Problem on my AP.
I log me in, go to the "enable" state an then I can't go to the "config" menu, why?
Is there a special option that I must turn on?
Thanks.
