Single SSID & DHCP
kdwillson
If possible, how would a Single SSID on a Aironet AP be able to provide LAN access to two different subnets?
I beleive a routing (router) needs to be present to route between two subnets.
In example,
     SSID "Visitor" can send IPv4 mobile devices to either subnet 192.168.1.0 or to subnet 10.0.0.0
Thank you!
Stephen Rodriguez
The only way to get that to work would be to do forced VLAN assignment from a AAA server. If you statically map the VLAN to the SSID you are locked to that one VLAN.
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
If you aren't concerned as to what subnet the user gets, so long as they get one of them, you can configure a dynamic vlan..
abwahid
Level 4
Level 4
Yes with the help of Dynamic vlan you can achieve this, if your AP have this feature.
gohussai
Level 4
Level 4
yes its is possible using dynamic VLAN assignment using ISE or ACS.
Plus that mode normally works if you want to group multiple APs (placed in different places) and you want that when ever client move to any locaiton SSID remain same but behind the scene VLAN changes, even the security can be same.
Hope this helps.
