single ssid mulpitle vlan mapping in flex connect trunk mode ISE vlan assignment
jerry.larson
How do I get multiple vlans assigned in my mapping on flex connect AP with the same SSID. For example, my ssid is GUSD, native vlan 98, Staff 104, student 128. I am using dynamic vlan assignment using ISE/radius. When I try to add the SSID a second time with a different SSID profile to assign a second vlan in mapping it says SSID with exact security already exists.
Abhishek Abhishek
Hello Jerry,
As per your scenario i can suggest you the following-
There is dynamic vlan assignment on the authentication server. You associate the SSID to the management interface, and then trunk dynamic interfaces to the wlc. The authentication server passes the interface name back to the WLC which maps clients to different vlans on the wired network.
Hope this will work
