Site Survey kit
Hello my friend.
Once again I'm here looking for your wisdom my company is looking for three options to get a site survey kit, you know Software and Cards, Does anyone some comments?
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
3 Accepted Solutions
For site survey I might recommend Airmagnet to measure your rf and map out your area of coverage. For layer 1 spectrum I might recommend MetaGeek wispy ..
kaaftab
Level 4
Level 4
Kindly check the following options
(AIRMAGNET)
http://www.airmagnet.com
- Seemed a little clunky.
- Complicated
- Multi-floor support.
- Custom reporting.
(EKAHAU SITE SURVEY)
http://www.ekahau.com/
- Extremely accurate AP location system, especially in small floor plan surveys.
- Does not support 64-Bit OS (as of 05-30-2010). 64-bit coming soon.
- Automated reporting.
- Simple interface.
- Includes AP planning features, that other survey software lacks.
- Has phone & email support.
(VISIWAVE SITE SURVEY)
http://www.visiwave.com
- Affordable
- Custom detailed reporting.
- Supports 64-Bit OS.
- Lacks true multi-floor support.
(MERITECH WIFI NETWORK SURVEY AND DESIGN)
http://www.meritechsolutions.com/
- Complicated.
- Business Headquarters: Kawasaki, Japan
vlad.mihailov
If you on the budget then check Metageek options: their spectrum analyzer is solid yet pretty cheap.
If you are building for future I'd suggest AirMagnet survey, and in the future you can add Planer option.
As for spectrum analyzer in that case check Cisco Spectrum Expert or Aiagnet again.
Ultimately you will need something to troubleshoot issues with. AirMagnet analyzer is great but expensive, OmniPeek is great too and cheaper. Again if on the budget check Metageek EyePi
5 Replies 5
Thank you everyone.
My company decided to bought Airmagnet kit for us site survey and troubleshooting activities.
kaaftab
Level 4
Level 4
(AIRMAGNET)
- Complicated
- Custom reporting.
- Simple interface.
- Affordable
- Complicated.
vlad.mihailov
