08-29-2010 05:07 PM - edited 07-03-2021 07:07 PM
Hi All
I have some wireless issues. Let me explain you,
We have WLAN infrastructure with Cisco Aironet WAP distributed on the floors. Recently I've recived complaint from one of the floor, that they are facing slowness while working on SQL Application. When I try to ping to any destination ip, its not stable. However,there is no weakness in the signal.
I have 2 ssid's configured on WAP,guest and employees.
I dont know what going on.
Any help will be appreciated
08-30-2010 02:48 AM
Please can anyone help me to resolve this issue
08-30-2010 01:52 PM
Hi Community,
I haven't recieve any reply from the experts,,,Please I need to solve this ASAP
08-30-2010 03:28 PM
Firstly, if it's SQL-related applications ONLY then it's not your WLAN. If it was your wireless LAN, ANYTHING and EVERYTHING would be slow.
Is the slowness to SQL-related applications related only to WLAN? Does it also include WIRED network?
I don't have any experience with SQL-related applications but I've seen a few where it all boils down to the server and the application particularly when someone's done something to it.
Use a wired/wireless packet sniffer and find out what the response time from the server is like. Maybe something in the applications is causing the server to respond that can overwhelm the wireless network.
08-30-2010 03:55 PM
Thanks for your response.
I would like to let you know I done some ping tests to WAP default gateway and packets are recvied with long intervals 500ms..800ms
Please Advice
08-31-2010 02:08 PM
Please can someone help me ASAP.
08-31-2010 04:52 PM
What have you found?
08-31-2010 05:05 PM
I need the experts guidance and until now i couldn't discovered where is the issue ?
I am need of your help
09-01-2010 04:51 AM
Experts,
I am annexing some snaps and WAP config for your review
Please this is very urgent and I need the resolution ASAP
Message was edited by: samirshaikh52
09-01-2010 05:11 AM
Finally got it working i missed out this command on radio interfaces
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
