software selection for AIR_CAP3602I
What is the correct option to select in config tool when I need to operate access point 3602I with WLC?
two options are shown SWAP3600-RCOVRY-k9 and SWLAP3600I-MESH-k9
no options for autonomous operation?
regards
Stephen Rodriguez
You want to order it with
SWAP3600-RCOVRY-k9
the other image is for MESH, which will work but has extra config on the WLC to allow it to join
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Hi steve,
thanks for your quick response.
In fact I don´t need MESH feature.
regards
harvisin
Level 3
Level 3
Hello Filibereto,
you should opt for  SWAP3600-RCOVRY-k9 as there is less configuration as compared to the MESH one or you need to follow the long and lengthy procedure to join.
