Some web-page is not open AP1231G and 802.11g WLAN card
yong1794
The AP1231G and AIR-PI21AG-W-K9 (a/b/g combo) WLAN card are configured with 128bit wep-key. ping test is ok, but some web site (sometimes ap http)site is not open or stop loading.
The DNS server setting is ok.wep-key setting is ok.
If I remove wep-key setting or disable 802.11g data-rate(except 1,2.2,5,11Mbps require). the web-site is open well. this web site openning problem is happend only between AP1231G and 802.11g WLAN cards.
* AP1231G firmware is new released c1200-k9w7-tar.122-13.JA2.tar.*
thax.
ndoshi
You are hitting CSCed50731 .
As I understand , This will be fixed in 12.2(13)JA3
Please check CCO software center , it will be out
soon
