09-11-2013 11:53 AM - edited 07-04-2021 12:49 AM
I am deploying a SPA3102 that is forwarding PSTN calls from an analog PBX to the IP address of a WiFi Handset. There is no server and no registration in this configuration, just IP dialing.Can you give me directions.
09-18-2013 05:11 PM
I hope you would not be able to connect wireless handsets for voice process & yes it’s datasheet shows you can be able to connect to your office or home data network through this device.
Cisco SPA3102 Phone Adapter with Router Cisco Small Business Voice Gateways and ATAs.
Please find the link for the datasheet & administration guide.
http://business.comcast.com/getstarted/pdf/Cisco3102data_sheet_c78_502105_unbranded.pdf
http://www.cisco.com/en/US/docs/voice_ip_comm/csbpvga/ata/administration/guide/ATA_AG_v3_NC-WEB.pdf
07-04-2014 08:32 AM
You can going in the right direction but... here in the network you need to one Access-point to connect WiFi handset to the SPA3102 gateway..
