splitting a floor heat map in Prime Infrastructure (PI)
ghalbedel
my 1st floor heat map has 118 APs and everytime I add one i get a pop-up telling me more than 100/floor is not recommended.
So what is the best way to split the floor so I have less than 100 APs per map?
Do I create it as a new floor?
Do I have to delete the current map to create 2 new ones.
Is there an easy way to just split the current map and retain the current AP placements on the  map?
Any recommendations would be helpful.
8 Replies 8
Rasika Nayanajith
Did you reach TAC on this ? I think that is the best avenue
what sort of environment is this to have that many AP on a single floor ?
Rasika
a high school
I would create multiple buildings in Prime & use it as a workaround
Rasika
same prob here... i have 122 in one floor.
did you find any solution, ghalbedel?
thanks!
I wound up creating 2 maps splitting the floor up into 2 sections and moving all the APs accordingly.
and in Prime they are still on same level?
yes
Have anyone tried this with next gen maps (Pi3.2++)?
