08-12-2024 12:36 PM - edited 08-12-2024 01:04 PM
we have new deployment of C9800-CL on version 17.14.1. We are trying to implement Cisco ISE with C9800-CL and make rule which redirect all mobile phones using random MAC to hotspot portal of ISE based on this guide https://www.cisco.com/c/en/us/support/docs/security/identity-services-engine/216021-using-hotspot-portal-to-instruct-users-o.html
Even it's not written there, we know we must have AAA Override and NAC State enabled on WLAN policy. Problem is that, immediately when I enable NAC State, SSID stop broadcasting and never returns to working state. But immediately I uncheck/disable NAC State option, SSID works fine. There is know bug that NAC State must be enabled from CLI, which we do.
We are using full Flexconnect mode for APs because we are deploying that config remotely and we want that all is working even controller is down. Full flexconnect I mean disabled Central Switching (because controller is remote), Central Authentication (because we want that authentication is from AP itself even in disconnected mode), Central DHCP (because DHCP relay is configured on VLAN interface on switch), Flex NAT/PAT (I do not know the purpose, but it's disabled
And I do not know if it is related to this NAC State (but from other forums it looks like yes), Hotspot portal is not launched at all on iPhone even authorization rule is matched for random MAC.
Any thoughts? I have raised Cisco support ticket, but still no answer from them.
08-12-2024 03:30 PM
What authentication are you using for the non MAC randomised devices?
08-13-2024 12:07 AM
@Haydn Andrews SSID is configured as L2 802.1x only. No L3, just AAA server group configured. It's not MAB authentication, it should be only 802.1x but MAC address should be checked on ISA for random address and if calling-station-id is random mac put there authorization rule which redirect that client to Hotspot portal as said in link I have written in original post.
08-12-2024 11:24 PM - edited 08-12-2024 11:26 PM
>... Problem is that, immediately when I enable NAC State, SSID stop broadcasting and never returns to working state.
- When that happens check the logs on the controller's logs with the CLI command show logging
+ Have a checkup of the 9800-CL configuration with the CLI command show tech wireless and feed the output to : Wireless Config Analyzer
( use the full command as mention in green = do not use a simple show tech as input for this procedure)
M.
08-13-2024 12:05 AM
@marce1000 honestly, review logs on 9800-CL is still nightmare for us, as we have migrated from 2504 and its totally different here. but I'll try.
regarding wireless config analyzer - didn't show me anything as error, just few warnings, but not related to this SSID
08-13-2024 12:07 AM
- Ok , but CLI command show logging is a simple command,
M.
08-13-2024 12:13 AM - edited 08-13-2024 12:16 AM
@marce1000 I have just tried...
controller-01(config)# wireless profile policy test-ise
controller-01(config)# shut
controller-01(config)# nac
controller-01(config)# no shut
show logging does not show anything... SSID just stop broadcasting. When I do following it starts broadcasting again
controller-01(config)# no nac
and our config is
aaa-override
accounting-interim
accounting-list AAA-accounting-ident-ise
no central authentication
no central dhcp
no central switching
dhcp-tlv-caching
exclusionlist timeout 1
http-tlv-caching
idle-timeout 7200
ipv4 flow monitor wireless-avc-basic input
ipv4 flow monitor wireless-avc-basic output
ipv6 flow monitor wireless-avc-basic-ipv6 input
ipv6 flow monitor wireless-avc-basic-ipv6 output
nac
radius-profiling
session-timeout 57600
vlan 524
no shutdown
wlan test-ise 3 test-ise
radio policy dot11 24ghz
radio policy dot11 5ghz
no security ft adaptive
security dot1x authentication-list AAA-Authentication-ISE
no shutdown
08-13-2024 12:22 AM
- An option could be to compare the issue against the gold starred advisory release 17.12.3 ;
the benefit of a vm/cloud controller is that it can easily be deployed besides another vm-based controller.
Though I presume that testing then is elaborate and 'not quick'
M.
08-13-2024 01:46 AM
You use flex AP diable central auth and as I know nac state and nac type only done if ypu use central auth' the can wlc check nac state but ap can not.
MHM
08-13-2024 03:42 AM
@MHM Cisco World and do you have any link to docs? each time I search for NAC State, there is nothing in configuration guide for 17.14.1. It's even hard to find the meaning of that setting. Central Authentication is problem in case controller drops or site-to-site vpn drops, when remote APs in branch office will not be able to reach controller.
08-26-2024 06:37 PM
@Tibor M
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/feature-matrix/ap-feature-matrix.html#_Toc118737963
FlexConnect Feature Matrix (IOS XE)
Table 6 FlexConnect Feature Matrix for Cisco Catalyst Controllers and Embedded Wireless Controllers
Features |
C9105/C9115/ |
C9120/C9124/ |
C9136 |
CW9162/CW9164/ |
CW9163 |
BYOD, NAC RADIUS, CWA Flex Central Auth. |
Yes(Central Auth) |
Yes(Central Auth) |
Yes(Central Auth) |
Yes(Central Auth) |
Yes(Central Auth) |
BYOD, NAC RADIUS, CWA Local Auth |
Yes(Central Auth) |
Yes(Central Auth) |
Yes(Central Auth) |
Yes(Central Auth) |
Yes(Central Auth) |
Same applies for Wave 2 APs further down the document. So NAC is not supported for your setup which is why the SSID goes inactive when you configure it.
08-13-2024 03:14 AM
- Another thing I was thinking of is the ISE version being used ,although I can not see an immediate correlation
For IOS-XE 17.14.1 , it's best to not have an older ISE version in place and or greater then 3.0 or above,
M.
08-13-2024 03:34 AM
@marce1000 we have ISE 3.4 now
08-13-2024 03:43 AM - edited 08-13-2024 03:47 AM
(sorry making some changes)
- That's good! Next one = https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213949-wireless-debugging-and-log-collection-on.html#toc-hId--476703037
Use the commands as mentioned (for wireless profile logging) , then enable your NAC state , after the SSID get's disabled check the content of the log files (on the bootflash: for instance) , as you named them.
M.
08-13-2024 06:21 AM
so I used wireless profile for logging and I just get following, nothing special why SSID stop broadcasting.
2024/08/13 15:15:48.148783465 {iosrp_R0-0}{1}: [pki] [23434]: (note): CRYPTO_PKI: Begin local cert chain retrieval.
2024/08/13 15:15:48.149071437 {iosrp_R0-0}{1}: [pki] [23434]: (note): CRYPTO_PKI: Done with local cert chain fetch 0.
2024/08/13 15:15:48.220206441 {iosrp_R0-0}{1}: [parser_cmd] [23434]: (note): id= 10.11.12.13@vty1:user=copyrightbanneruser cmd: 'show banner login' SUCCESS 2024/08/13 15:15:48.216 CET
2024/08/13 15:15:48.564198589 {iosrp_R0-0}{1}: [iosrp] [23434]: (note): Aug 13 13:15:48.564: %WEBSERVER-5-SESS_TIMEOUT: Chassis 1 Session timeout from host 10.11.12.13 by user 'admin' using crypto cipher 'TLS_AES_256_GCM_SHA384'
2024/08/13 15:15:49.859996997 {iosrp_R0-0}{1}: [pki] [23434]: (note): CRYPTO_PKI: Begin local cert chain retrieval.
2024/08/13 15:15:49.860357284 {iosrp_R0-0}{1}: [pki] [23434]: (note): CRYPTO_PKI: Done with local cert chain fetch 0.
2024/08/13 15:15:49.897354259 {iosrp_R0-0}{1}: [pki] [23434]: (note): CRYPTO_PKI: Begin local cert chain retrieval.
2024/08/13 15:15:49.897652136 {iosrp_R0-0}{1}: [pki] [23434]: (note): CRYPTO_PKI: Done with local cert chain fetch 0.
2024/08/13 15:15:49.937042223 {iosrp_R0-0}{1}: [parser_cmd] [23434]: (note): id= 10.11.12.13@vty1:user=copyrightbanneruser cmd: 'show banner login' SUCCESS 2024/08/13 15:15:49.936 CET
2024/08/13 15:15:49.958509755 {iosrp_R0-0}{1}: [pki] [23434]: (note): CRYPTO_PKI: Begin local cert chain retrieval.
2024/08/13 15:15:49.958872360 {iosrp_R0-0}{1}: [pki] [23434]: (note): CRYPTO_PKI: Done with local cert chain fetch 0.
2024/08/13 15:15:49.963354948 {iosrp_R0-0}{1}: [parser_cmd] [23434]: (note): id= 10.11.12.13@vty1:user=copyrightbanneruser cmd: 'show banner login' SUCCESS 2024/08/13 15:15:49.963 CET
2024/08/13 15:15:57.099583217 {iosrp_R0-0}{1}: [parser_cmd] [23434]: (note): id= 10.11.12.13@vty0:user=admin cmd: 'conf t' SUCCESS 2024/08/13 15:15:57.097 CET
2024/08/13 15:16:02.397388756 {iosrp_R0-0}{1}: [parser_cmd] [23434]: (note): id= 10.11.12.13@vty0:user=admin cmd: 'wireless profile policy ssid-ise' SUCCESS 2024/08/13 15:16:02.391 CET
2024/08/13 15:16:07.170911164 {wncd_x_R0-0}{1}: [wlanmgr-db] [14288]: (note): Policy profile config modify notified, profile: ssid-ise, status: UP, ref-count: 0, state: No notifications
2024/08/13 15:16:07.170912543 {wncd_x_R0-0}{1}: [wlanmgr-db] [14288]: (note): Policy profile external config admin status: disabled
2024/08/13 15:16:07.171306984 {wncd_x_R0-0}{1}: [tag-manager-db] [14288]: (note): Started processing Policy profile modify; profile: ssid-ise
2024/08/13 15:16:07.171318238 {wncd_x_R0-0}{1}: [tag-manager-db] [14288]: (note): PROPAGATE: policy tag name company-policy-prague-ise used by policy profile ssid-ise
2024/08/13 15:16:07.171412273 {wncd_x_R0-0}{1}: [tag-manager-db] [14288]: (note): Map found for wlan ssid-ise,policy ssid-ise in tag company-policy-prague-ise
2024/08/13 15:16:07.171499441 {wncd_x_R0-0}{1}: [tag-manager-db] [14288]: (note): 70db.987e.7740 &&& propogating data to this AP &&& wlan ssid-ise,policy ssid-ise and tag company-policy-prague-ise
2024/08/13 15:16:07.171590447 {wncd_x_R0-0}{1}: [apmgr-capwap-config] [14288]: (note): MAC: 70db.987e.7740 Defer config update : Event already scheduled. Tag revalidate : 0
2024/08/13 15:16:07.171720205 {wncd_x_R0-0}{1}: [tag-manager-db] [14288]: (ERR): Failed to get first WLAN-VRF record
2024/08/13 15:16:07.172127809 {mobilityd_R0-0}{1}: [wlanmgr-db] [15681]: (note): Policy profile config modify notified, profile: ssid-ise, status: UP, ref-count: 0, state: No notifications
2024/08/13 15:16:07.172131678 {mobilityd_R0-0}{1}: [wlanmgr-db] [15681]: (note): Policy profile external config admin status: disabled
2024/08/13 15:16:07.172491615 {wncmgrd_R0-0}{1}: [wlanmgr-db] [14067]: (note): Policy profile config modify notified, profile: ssid-ise, status: UP, ref-count: 0, state: No notifications
2024/08/13 15:16:07.172529047 {wncmgrd_R0-0}{1}: [wlanmgr-db] [14067]: (note): Policy profile external config admin status: disabled
2024/08/13 15:16:07.173261785 {wncd_x_R0-0}{1}: [apmgr-bssid] [14288]: (note): MAC: 70db.987e.7740 Process update on bssid context slot:0 bss:0 curr state:2 radio-admin:Enable radio-confg:Enable map:Enable wlan:Enable policy:Disable radio restart:Yes
2024/08/13 15:16:07.173294040 {wncd_x_R0-0}{1}: [apmgr-bssid] [14288]: (note): MAC: 70db.987e.7740 Do not resend OWE transition mode: wlan profile unavailable
2024/08/13 15:16:07.173295229 {wncd_x_R0-0}{1}: [apmgr-bssid] [14288]: (note): MAC: 70db.987e.7740 Process update on bssid context slot:1 bss:0 curr state:2 radio-admin:Enable radio-confg:Enable map:Enable wlan:Enable policy:Disable radio restart:Yes
2024/08/13 15:16:07.173297248 {wncd_x_R0-0}{1}: [apmgr-bssid] [14288]: (note): MAC: 70db.987e.7740 Do not resend OWE transition mode: wlan profile unavailable
2024/08/13 15:16:07.174175326 {iosrp_R0-0}{1}: [parser_cmd] [23434]: (note): id= 10.11.12.13@vty0:user=admin cmd: 'shut' SUCCESS 2024/08/13 15:16:07.166 CET
2024/08/13 15:16:10.529215995 {wncd_x_R0-0}{1}: [wlanmgr-db] [14288]: (note): Policy profile config modify notified, profile: ssid-ise, status: Down, ref-count: 0, state: No notifications
2024/08/13 15:16:10.529217574 {wncd_x_R0-0}{1}: [wlanmgr-db] [14288]: (note): Policy profile external config admin status: disabled
2024/08/13 15:16:10.529641181 {mobilityd_R0-0}{1}: [wlanmgr-db] [15681]: (note): Policy profile config modify notified, profile: ssid-ise, status: Down, ref-count: 0, state: No notifications
2024/08/13 15:16:10.529642470 {mobilityd_R0-0}{1}: [wlanmgr-db] [15681]: (note): Policy profile external config admin status: disabled
2024/08/13 15:16:10.529782203 {wncmgrd_R0-0}{1}: [wlanmgr-db] [14067]: (note): Policy profile config modify notified, profile: ssid-ise, status: Down, ref-count: 0, state: No notifications
2024/08/13 15:16:10.529783412 {wncmgrd_R0-0}{1}: [wlanmgr-db] [14067]: (note): Policy profile external config admin status: disabled
2024/08/13 15:16:10.530564697 {iosrp_R0-0}{1}: [parser_cmd] [23434]: (note): id= 10.11.12.13@vty0:user=admin cmd: 'no nac' SUCCESS 2024/08/13 15:16:10.525 CET
2024/08/13 15:16:13.014388771 {wncd_x_R0-0}{1}: [wlanmgr-db] [14288]: (note): Policy profile config modify notified, profile: ssid-ise, status: Down, ref-count: 0, state: No notifications
2024/08/13 15:16:13.014389810 {wncd_x_R0-0}{1}: [wlanmgr-db] [14288]: (note): Policy profile external config admin status: enabled
2024/08/13 15:16:13.014541217 {wncd_x_R0-0}{1}: [tag-manager-db] [14288]: (ERR): Failed to retrieve VLAN Config from policy profile
2024/08/13 15:16:13.014593712 {wncd_x_R0-0}{1}: [tag-manager-db] [14288]: (note): Started processing Policy profile modify; profile: ssid-ise
2024/08/13 15:16:13.014597011 {wncd_x_R0-0}{1}: [tag-manager-db] [14288]: (note): PROPAGATE: policy tag name company-policy-prague-ise used by policy profile ssid-ise
2024/08/13 15:16:13.014611004 {wncd_x_R0-0}{1}: [tag-manager-db] [14288]: (note): Map found for wlan ssid-ise,policy ssid-ise in tag company-policy-prague-ise
2024/08/13 15:16:13.014633263 {wncd_x_R0-0}{1}: [tag-manager-db] [14288]: (note): 70db.987e.7740 &&& propogating data to this AP &&& wlan ssid-ise,policy ssid-ise and tag company-policy-prague-ise
2024/08/13 15:16:13.014703599 {wncd_x_R0-0}{1}: [apmgr-capwap-config] [14288]: (note): MAC: 70db.987e.7740 Defer config update : Event already scheduled. Tag revalidate : 0
2024/08/13 15:16:13.015014650 {mobilityd_R0-0}{1}: [wlanmgr-db] [15681]: (note): Policy profile config modify notified, profile: ssid-ise, status: Down, ref-count: 0, state: No notifications
2024/08/13 15:16:13.015015650 {mobilityd_R0-0}{1}: [wlanmgr-db] [15681]: (note): Policy profile external config admin status: enabled
2024/08/13 15:16:13.015153903 {wncmgrd_R0-0}{1}: [wlanmgr-db] [14067]: (note): Policy profile config modify notified, profile: ssid-ise, status: Down, ref-count: 0, state: No notifications
2024/08/13 15:16:13.015155133 {wncmgrd_R0-0}{1}: [wlanmgr-db] [14067]: (note): Policy profile external config admin status: enabled
2024/08/13 15:16:13.015690416 {wncd_x_R0-0}{1}: [apmgr-bssid] [14288]: (note): MAC: 70db.987e.7740 Process update on bssid context slot:0 bss:0 curr state:2 radio-admin:Enable radio-confg:Enable map:Enable wlan:Enable policy:Enable radio restart:Yes
2024/08/13 15:16:13.015746319 {wncd_x_R0-0}{1}: [apmgr-bssid] [14288]: (ERR): Anchor table root is NULL for policy
2024/08/13 15:16:13.015929271 {wncd_x_R0-0}{1}: [apmgr-bssid] [14288]: (note): MAC: 70db.987e.7740 Enable BSSID context: Updating WLAN policy info for slot-id:0, VAP-id: 1
2024/08/13 15:16:13.015958597 {wncd_x_R0-0}{1}: [apmgr-bssid] [14288]: (ERR): Invalid bssid or bssid ctxt not yet enabled.Bssid mac : 70db.987e.7740 ,State : 2, Error : Success
2024/08/13 15:16:13.015958847 {wncd_x_R0-0}{1}: [apmgr-bssid] [14288]: (ERR): Failed to get radio type from BSSID. Invalid (NULL) bssid handle
2024/08/13 15:16:13.016331818 {wncd_x_R0-0}{1}: [apmgr-bssid] [14288]: (note): MAC: 70db.987e.7740 Process update on bssid context slot:1 bss:0 curr state:2 radio-admin:Enable radio-confg:Enable map:Enable wlan:Enable policy:Enable radio restart:Yes
2024/08/13 15:16:13.016343202 {wncd_x_R0-0}{1}: [apmgr-bssid] [14288]: (ERR): Anchor table root is NULL for policy
2024/08/13 15:16:13.016399845 {wncd_x_R0-0}{1}: [apmgr-bssid] [14288]: (note): MAC: 70db.987e.7740 Enable BSSID context: Updating WLAN policy info for slot-id:1, VAP-id: 1
2024/08/13 15:16:13.016406352 {wncd_x_R0-0}{1}: [apmgr-bssid] [14288]: (ERR): Invalid bssid or bssid ctxt not yet enabled.Bssid mac : 70db.987e.774f ,State : 2, Error : Success
2024/08/13 15:16:13.016406522 {wncd_x_R0-0}{1}: [apmgr-bssid] [14288]: (ERR): Failed to get radio type from BSSID. Invalid (NULL) bssid handle
2024/08/13 15:16:13.019345930 {iosrp_R0-0}{1}: [parser_cmd] [23434]: (note): id= 10.11.12.13@vty0:user=admin cmd: 'no shut' SUCCESS 2024/08/13 15:16:13.011 CET
2024/08/13 15:16:21.871842253 {wncd_x_R0-0}{1}: [wlanmgr-db] [14288]: (note): Policy profile config modify notified, profile: ssid-ise, status: UP, ref-count: 2, state: No notifications
2024/08/13 15:16:21.871845292 {wncd_x_R0-0}{1}: [wlanmgr-db] [14288]: (note): Policy profile external config admin status: disabled
2024/08/13 15:16:21.871845442 {wncd_x_R0-0}{1}: [wlanmgr-db] [14288]: (note): Ref-count not zero, delayed update will happen
2024/08/13 15:16:21.871972850 {wncd_x_R0-0}{1}: [tag-manager-db] [14288]: (note): Started processing Policy profile modify; profile: ssid-ise
2024/08/13 15:16:21.871975769 {wncd_x_R0-0}{1}: [tag-manager-db] [14288]: (note): PROPAGATE: policy tag name company-policy-prague-ise used by policy profile ssid-ise
2024/08/13 15:16:21.871994850 {wncd_x_R0-0}{1}: [tag-manager-db] [14288]: (note): Map found for wlan ssid-ise,policy ssid-ise in tag company-policy-prague-ise
2024/08/13 15:16:21.872033521 {wncd_x_R0-0}{1}: [tag-manager-db] [14288]: (note): 70db.987e.7740 &&& propogating data to this AP &&& wlan ssid-ise,policy ssid-ise and tag company-policy-prague-ise
2024/08/13 15:16:21.872091773 {wncd_x_R0-0}{1}: [apmgr-capwap-config] [14288]: (note): MAC: 70db.987e.7740 Defer config update : Event already scheduled. Tag revalidate : 0
2024/08/13 15:16:21.872133483 {wncd_x_R0-0}{1}: [wlanmgr-db] [14288]: (note): Successfully initiated policy ref count cleanup timer for 120-sec
2024/08/13 15:16:21.872405913 {mobilityd_R0-0}{1}: [wlanmgr-db] [15681]: (note): Policy profile config modify notified, profile: ssid-ise, status: UP, ref-count: 0, state: No notifications
2024/08/13 15:16:21.872406982 {mobilityd_R0-0}{1}: [wlanmgr-db] [15681]: (note): Policy profile external config admin status: disabled
2024/08/13 15:16:21.872560228 {wncmgrd_R0-0}{1}: [wlanmgr-db] [14067]: (note): Policy profile config modify notified, profile: ssid-ise, status: UP, ref-count: 0, state: No notifications
2024/08/13 15:16:21.872561278 {wncmgrd_R0-0}{1}: [wlanmgr-db] [14067]: (note): Policy profile external config admin status: disabled
2024/08/13 15:16:21.872781882 {wncd_x_R0-0}{1}: [tag-manager-db] [14288]: (ERR): Failed to get first WLAN-VRF record
2024/08/13 15:16:21.872976698 {wncd_x_R0-0}{1}: [apmgr-bssid] [14288]: (note): MAC: 70db.987e.7740 Process update on bssid context slot:0 bss:0 curr state:1 radio-admin:Enable radio-confg:Enable map:Enable wlan:Enable policy:Disable radio restart:Yes
2024/08/13 15:16:21.872977348 {wncd_x_R0-0}{1}: [apmgr-bssid] [14288]: (note): MAC: 70db.987e.7740 Process bssid ctxt update- Disable bssid context for update. Sending disable notification to CO
2024/08/13 15:16:21.873007444 {wncd_x_R0-0}{1}: [client-orch-sm] [14288]: (note): CO process BSSID event from apmgr . Received BSSID event 1 from AP manager for bssid 70db.987e.7740 wtp mac 70db.987e.7740 vap id 1, slot id 0, per BSSID client count: 0
2024/08/13 15:16:21.873038789 {wncd_x_R0-0}{1}: [client-orch-sm] [14288]: (note): Delete client from bssid. Sending ack notification to apmgr for bssid disable/delete reason: 6, CO_CLIENT_DELETE_REASON_BSSID_DOWN, BSSID: 70db.987e.7740
2024/08/13 15:16:21.873053661 {wncd_x_R0-0}{1}: [apmgr-bssid] [14288]: (note): MAC: 70db.987e.7740 Process update on bssid context slot:1 bss:0 curr state:1 radio-admin:Enable radio-confg:Enable map:Enable wlan:Enable policy:Disable radio restart:Yes
2024/08/13 15:16:21.873053861 {wncd_x_R0-0}{1}: [apmgr-bssid] [14288]: (note): MAC: 70db.987e.7740 Process bssid ctxt update- Disable bssid context for update. Sending disable notification to CO
2024/08/13 15:16:21.873055191 {wncd_x_R0-0}{1}: [client-orch-sm] [14288]: (note): CO process BSSID event from apmgr . Received BSSID event 1 from AP manager for bssid 70db.987e.774f wtp mac 70db.987e.7740 vap id 1, slot id 1, per BSSID client count: 0
2024/08/13 15:16:21.873056290 {wncd_x_R0-0}{1}: [client-orch-sm] [14288]: (note): Delete client from bssid. Sending ack notification to apmgr for bssid disable/delete reason: 6, CO_CLIENT_DELETE_REASON_BSSID_DOWN, BSSID: 70db.987e.774f
2024/08/13 15:16:21.873386322 {wncd_x_R0-0}{1}: [apmgr-bssid] [14288]: (note): MAC: 70db.987e.7740 Client delete ACK from co for bssid 70db.987e.7740 slot id 0, state: 4
2024/08/13 15:16:21.873522686 {wncd_x_R0-0}{1}: [apmgr-db] [14288]: (ERR): 70db.987e.7740 Failed to add AP radio wlan-id stats record.Reason: Success
2024/08/13 15:16:21.873549883 {wncd_x_R0-0}{1}: [apmgr-bssid] [14288]: (note): MAC: 70db.987e.7740 Disable bssid : Slot : 0, Bssid :0, IFID : 0, WLAN : ssid-ise
2024/08/13 15:16:21.873564596 {wncd_x_R0-0}{1}: [apmgr-bssid] [14288]: (note): MAC: 70db.987e.7740 Process update on bssid context slot:0 bss:0 curr state:2 radio-admin:Enable radio-confg:Enable map:Enable wlan:Enable policy:Disable radio restart:Yes
2024/08/13 15:16:21.874046885 {wncd_x_R0-0}{1}: [apmgr-bssid] [14288]: (note): MAC: 70db.987e.7740 Client delete ACK from co for bssid 70db.987e.774f slot id 1, state: 4
2024/08/13 15:16:21.874096861 {wncd_x_R0-0}{1}: [apmgr-db] [14288]: (ERR): 70db.987e.7740 Failed to add AP radio wlan-id stats record.Reason: Success
2024/08/13 15:16:21.874098120 {wncd_x_R0-0}{1}: [apmgr-db] [14288]: (ERR): 70db.987e.7740 Failed to add AP radio wlan-id stats record.Reason: Success
2024/08/13 15:16:21.874099040 {wncd_x_R0-0}{1}: [apmgr-db] [14288]: (ERR): 70db.987e.7740 Failed to add AP radio wlan-id stats record.Reason: Success
2024/08/13 15:16:21.874107406 {wncd_x_R0-0}{1}: [apmgr-bssid] [14288]: (note): MAC: 70db.987e.7740 Disable bssid : Slot : 1, Bssid :0, IFID : 0, WLAN : ssid-ise
2024/08/13 15:16:21.874114682 {wncd_x_R0-0}{1}: [wlanmgr-db] [14288]: (note): Successfully stopped policy ref count data cleanup timer
2024/08/13 15:16:21.874122069 {wncd_x_R0-0}{1}: [wlanmgr-db] [14288]: (note): Policy profile config modify notified, profile: ssid-ise, status: Down, ref-count: 0, state: Update pending
2024/08/13 15:16:21.874122238 {wncd_x_R0-0}{1}: [wlanmgr-db] [14288]: (note): Policy profile external config admin status: disabled
2024/08/13 15:16:21.874145028 {wncd_x_R0-0}{1}: [wlanmgr-db] [14288]: (note): Successfully stopped wlan ref count data cleanup timer
2024/08/13 15:16:21.874145507 {wncd_x_R0-0}{1}: [wlanmgr-db] [14288]: (note): No notifications pending for WlanId: 3, profile: ssid-ise, SSID: ssid-ise; Triggering record updates if any.
2024/08/13 15:16:21.874146327 {wncd_x_R0-0}{1}: [apmgr-bssid] [14288]: (note): MAC: 70db.987e.7740 Process update on bssid context slot:1 bss:0 curr state:2 radio-admin:Enable radio-confg:Enable map:Enable wlan:Enable policy:Disable radio restart:Yes
2024/08/13 15:16:21.875088864 {iosrp_R0-0}{1}: [parser_cmd] [23434]: (note): id= 10.11.12.13@vty0:user=admin cmd: 'shut' SUCCESS 2024/08/13 15:16:21.868 CET
2024/08/13 15:16:24.219285201 {wncd_x_R0-0}{1}: [wlanmgr-db] [14288]: (note): Policy profile config modify notified, profile: ssid-ise, status: Down, ref-count: 0, state: No notifications
2024/08/13 15:16:24.219287090 {wncd_x_R0-0}{1}: [wlanmgr-db] [14288]: (note): Policy profile external config admin status: disabled
2024/08/13 15:16:24.219825212 {mobilityd_R0-0}{1}: [wlanmgr-db] [15681]: (note): Policy profile config modify notified, profile: ssid-ise, status: Down, ref-count: 0, state: No notifications
2024/08/13 15:16:24.219827041 {mobilityd_R0-0}{1}: [wlanmgr-db] [15681]: (note): Policy profile external config admin status: disabled
2024/08/13 15:16:24.220044627 {wncmgrd_R0-0}{1}: [wlanmgr-db] [14067]: (note): Policy profile config modify notified, profile: ssid-ise, status: Down, ref-count: 0, state: No notifications
2024/08/13 15:16:24.220046236 {wncmgrd_R0-0}{1}: [wlanmgr-db] [14067]: (note): Policy profile external config admin status: disabled
2024/08/13 15:16:24.222692985 {iosrp_R0-0}{1}: [parser_cmd] [23434]: (note): id= 10.11.12.13@vty0:user=admin cmd: 'nac' SUCCESS 2024/08/13 15:16:24.214 CET
2024/08/13 15:16:28.166350923 {wncd_x_R0-0}{1}: [wlanmgr-db] [14288]: (note): Policy profile config modify notified, profile: ssid-ise, status: Down, ref-count: 0, state: No notifications
2024/08/13 15:16:28.166351962 {wncd_x_R0-0}{1}: [wlanmgr-db] [14288]: (note): Policy profile external config admin status: enabled
2024/08/13 15:16:28.166585940 {wncd_x_R0-0}{1}: [tag-manager-db] [14288]: (ERR): Failed to retrieve VLAN Config from policy profile
2024/08/13 15:16:28.166597604 {wncd_x_R0-0}{1}: [tag-manager-db] [14288]: (note): Started processing Policy profile modify; profile: ssid-ise
2024/08/13 15:16:28.166603831 {wncd_x_R0-0}{1}: [tag-manager-db] [14288]: (note): PROPAGATE: policy tag name company-policy-prague-ise used by policy profile ssid-ise
2024/08/13 15:16:28.166634527 {wncd_x_R0-0}{1}: [tag-manager-db] [14288]: (note): Map found for wlan ssid-ise,policy ssid-ise in tag company-policy-prague-ise
2024/08/13 15:16:28.166689330 {wncd_x_R0-0}{1}: [tag-manager-db] [14288]: (note): 70db.987e.7740 &&& propogating data to this AP &&& wlan ssid-ise,policy ssid-ise and tag company-policy-prague-ise
2024/08/13 15:16:28.166780556 {wncd_x_R0-0}{1}: [apmgr-capwap-config] [14288]: (note): MAC: 70db.987e.7740 Defer config update : Event already scheduled. Tag revalidate : 0
2024/08/13 15:16:28.167083621 {mobilityd_R0-0}{1}: [wlanmgr-db] [15681]: (note): Policy profile config modify notified, profile: ssid-ise, status: Down, ref-count: 0, state: No notifications
2024/08/13 15:16:28.167117475 {mobilityd_R0-0}{1}: [wlanmgr-db] [15681]: (note): Policy profile external config admin status: enabled
2024/08/13 15:16:28.167335030 {wncmgrd_R0-0}{1}: [wlanmgr-db] [14067]: (note): Policy profile config modify notified, profile: ssid-ise, status: Down, ref-count: 0, state: No notifications
2024/08/13 15:16:28.167336040 {wncmgrd_R0-0}{1}: [wlanmgr-db] [14067]: (note): Policy profile external config admin status: enabled
2024/08/13 15:16:28.167893232 {wncd_x_R0-0}{1}: [apmgr-bssid] [14288]: (note): MAC: 70db.987e.7740 Process update on bssid context slot:0 bss:0 curr state:2 radio-admin:Enable radio-confg:Enable map:Enable wlan:Enable policy:Enable radio restart:Yes
2024/08/13 15:16:28.167922758 {wncd_x_R0-0}{1}: [apmgr-bssid] [14288]: (ERR): 70db.987e.7740 Enable bssid ctxt : Not a valid local auth config slot: 0, WLAN ID: 3
2024/08/13 15:16:28.167930554 {wncd_x_R0-0}{1}: [apmgr-bssid] [14288]: (note): MAC: 70db.987e.7740 Do not resend OWE transition mode: wlan profile unavailable
2024/08/13 15:16:28.167931404 {wncd_x_R0-0}{1}: [apmgr-bssid] [14288]: (note): MAC: 70db.987e.7740 Process update on bssid context slot:1 bss:0 curr state:2 radio-admin:Enable radio-confg:Enable map:Enable wlan:Enable policy:Enable radio restart:Yes
2024/08/13 15:16:28.167935152 {wncd_x_R0-0}{1}: [apmgr-bssid] [14288]: (ERR): 70db.987e.7740 Enable bssid ctxt : Not a valid local auth config slot: 1, WLAN ID: 3
2024/08/13 15:16:28.167937101 {wncd_x_R0-0}{1}: [apmgr-bssid] [14288]: (note): MAC: 70db.987e.7740 Do not resend OWE transition mode: wlan profile unavailable
2024/08/13 15:16:28.168517352 {iosrp_R0-0}{1}: [parser_cmd] [23434]: (note): id= 10.11.12.13@vty0:user=admin cmd: 'no shut' SUCCESS 2024/08/13 15:16:28.163 CET
2024/08/13 15:16:29.659424027 {iosrp_R0-0}{1}: [iosrp] [23434]: (note): Aug 13 13:16:29.659: %SYS-5-CONFIG_I: Configured from console by admin on vty0 (10.11.12.13)
2024/08/13 15:16:29.659612036 {iosrp_R0-0}{1}: [parser_cmd] [23434]: (note): id= 10.11.12.13@vty0:user=admin cmd: 'end' SUCCESS 2024/08/13 15:16:29.658 CET
