Suddenly few users are not authenticating through AAA
banavathkiran
I have two radius servers configured in cisco wlc 2504, few users are unable to authenticate and connect to WLAN. For some uses Im getting these logs
71 Mon Aug 5 12:54:58 2013 RADIUS server 172.16.100.254:1812 failed to respond to request (ID 208) for client 00:22:fa:98:a4:68 / user 'unknown'
72 Mon Aug 5 12:54:56 2013 RADIUS server 172.16.100.254:1812 failed to respond to request (ID 197) for client 00:00:01:d7:00:00 / user 'unknown'
73 Mon Aug 5 12:54:27 2013 RADIUS server 172.16.100.254:1812 failed to respond to request (ID 183) for client 00:22:fa:98:a4:68 / user 'unknown'
74 Mon Aug 5 12:54:26 2013 RADIUS server 172.16.100.254:1812 activated in global list
75 Mon Aug 5 12:54:26 2013 RADIUS server 172.16.100.200:1812 deactivated in global list
76 Mon Aug 5 12:54:26 2013 RADIUS server 172.16.100.200:1812 deactivated in global list
77 Mon Aug 5 12:54:26 2013 RADIUS server 172.16.100.200:1812 failed to respond to request (ID 171) for client 00:00:01:d7:00:00 / user 'unknown'
78 Mon Aug 5 12:54:02 2013 Rogue AP : 1a:87:96:8d:0f:cd removed from Base Radio MAC : 00:24:97:15:69:90 Interface no:0(802.11n(2.4 GHz))
79 Mon Aug 5 12:54:02 2013 Rogue AP : 1a:87:96:8d:0f:cd removed from Base Radio MAC : 00:21:a0:26:64:d0 Interface no:0(802.11n(2.4 GHz))
80 Mon Aug 5 12:54:02 2013 Rogue AP : 1a:87:96:8d:0f:cd removed from Base Radio MAC : 00:21:a0:28:57:10 Interface no:0(802.11n(2.4 GHz))
81 Mon Aug 5 12:53:56 2013 RADIUS server 172.16.100.254:1812 failed to respond to request (ID 140) for client 00:22:fa:98:a4:68 / user 'unknown'
Please let me what is cause for this problem. my radius servers are over WAN.
Fallback is OFF before, I have confgired it to Active now but same problem persists.
Scott Fella
Check your radius server logs
-Scott
Scott Fella
-Scott
Hi scott Thank you for the rply.
The primary radius server services got hanged up because of which clients are unable to authenticate.
I have disabled my primary server then only clients are able to authenticate using secondary server.
scott , what do you recommend failover to be OFF or Active or Passive?
And after as I have pasted the logs above, even now I cloud able to see those longs again
What does this mean? controller is unable to send the username and password to radius server? This is why servers in failing to respond?
Amjad Abdullah
Scott just guided you to the right spot.
You may also make sure that the credentials are valid on the machines that fail authentication. (in case you don't have direct access to the radius server).
Rating useful replies is more useful than saying "Thank you"
