Switch Port to Cisco Prime Infrastructure Appliance
Hello.
I got a Doubt about the Switch Port in my Cisco Switch to a Appliance of Prime Infrastructure.
This port needs to be a Switchport access or a Switchport Trunk?
Which is your Recommendation about this? What is the best Practices?
Thanks a lot.
Ric Beeching
Level 7
Level 7
Access Port should work fine. You do not configure a VLAN on the appliance itself, just the IP address / subnet and default gateway.
Ric
Please rate helpful / correct posts
Ric Beeching
Level 7
Level 7
Ric
