TACACS config in 5508 WLAN controller not working
tdennehy
Scenario:
Standing up new WLC.  Local auth works for getting into the box.  TACACS does not.
TACACS config on WLC appears to be correct, matching other known-good systems.
The owner of the ACS box states, "ACS reports show pass auth, but it routes your session back to prompt" after trying to login via SSH.
Anyone have an idea?
Thanks in advance!
9 Replies 9
how does "show tacacs summary" looks like on your WLC ?
Rasika
tdennehy
Authentication Servers
Idx  Server Address    Port    State     Tout  MgmtTout
1    10.155.20.36      49      Enabled   10    2
2    10.11.119.19      49      Enabled   10    2
Authorization Servers
Accounting Servers
1    10.155.20.36      49      Enabled   10    10
2    10.11.119.19      49      Enabled   10    10
can you do a debug aaa tacacs enable when someone is trying to authenticate and capture the output?
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
(jkn001-011-wc04) >debug aaa tacacs enable
(jkn001-011-wc04) >*tplusTransportThread: Dec 18 22:16:15.646: Forwarding request to 10.155.20.36 port=49
*tplusTransportThread: Dec 18 22:16:15.659: tplus auth response: type=1 seq_no=2 session_id=8c5f3dd9 length=16 encrypted=0
*tplusTransportThread: Dec 18 22:16:15.659: TPLUS_AUTHEN_STATUS_GETPASS
*tplusTransportThread: Dec 18 22:16:15.659: auth_cont get_pass reply: pkt_length=29
*tplusTransportThread: Dec 18 22:16:15.659: processTplusAuthResponse: Continue auth transaction
*tplusTransportThread: Dec 18 22:16:15.985: tplus auth response: type=1 seq_no=4 session_id=8c5f3dd9 length=6 encrypted=0
*tplusTransportThread: Dec 18 22:16:15.986: tplus_make_author_request() from tplus_authen_passed returns rc=0
*tplusTransportThread: Dec 18 22:16:16.286: Forwarding request to 10.155.20.36 port=49
*tplusTransportThread: Dec 18 22:16:16.300: ATHR Socket closed underneath
*tplusTransportThread: Dec 18 22:16:18.906: No auth response from: 10.155.20.36, retrying with next server
*tplusTransportThread: Dec 18 22:16:18.906: Preparing message for retransmit. Decrypting first
*tplusTransportThread: Dec 18 22:16:18.906: Forwarding request to 10.11.119.19 port=49
*tplusTransportThread: Dec 18 22:16:18.925: ATHR Socket closed underneath
*tplusTransportThread: Dec 18 22:16:21.530: No auth response from: 10.11.119.19, retrying with next server
*tplusTransportThread: Dec 18 22:16:21.530: Preparing message for retransmit. Decrypting first
*tplusTransportThread: Dec 18 22:16:21.530: Forwarding request to 10.155.20.36 port=49
*tplusTransportThread: Dec 18 22:16:21.544: ATHR Socket closed underneath
*tplusTransportThread: Dec 18 22:16:24.150: Exhausted all available servers for Auth/Author packet
As you can see clearly WLC trying all configured servers, but no response coming from TACACS server.
Check port TCP/UDP port 49 is open between WLC & this server.
Rasika
Rasika, we both agree, as usual.  There is no response from the servers.  Either the port is blocked or the servers are not configured.  I have usually come to this conclusion before I post, just to see if everyone agrees with me.  Since our CWNE community is very small, I go here for confirmation.
Congrats, by the way.
Thanks for congrats (I hope it is for CWNP stuff)
Regarding your issue, try to increase timeout value & see if that helps. Below post mentioned something similar
https://supportforums.cisco.com/discussion/11480676/issues-wlc-7x-and-cisco-acs-51-web-auth
If you can take a packet capture where your TACACS server connected while you are doing a test, that will show us what's going on at that end.
I believe you have full reachability between WLC management & all these servers
Rasika
*** Pls rate all useful responses ****
Yep... I follow all your posts.  Thanks for putting that out there.
In the GUI I could change the timeout to ten seconds.  Had no effect.  I even turned them off and used the CLI, then turned back on.  Still no effect.
Sir,
Was this ever resolved? I'm having the same tacacs+ issue and haven't been able to resolve.
Jeff
