ā10-23-2013 08:38 AM - edited ā07-04-2021 01:08 AM
Tengo estos mensajes en los log de los AP, quien me puede ayudar o que alla pasado por lo mismo, Gracias crojas@kaufmann.cl
230d.90fe Reassociated KEY_MGMT[NONE]
Oct 23 10:33:48.247 -0400: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 0017.
23a4.497b Reassociated KEY_MGMT[NONE]
Oct 23 10:33:51.266 -0400: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 0017.
2301.a4af Reassociated KEY_MGMT[NONE]
Oct 23 10:33:55.006 -0400: %DOT11-6-ROAMED: Station 0017.230d.90fe Roamed to 003
a.98b0.f400
Oct 23 10:33:55.006 -0400: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthentic
ating Station 0017.230d.90fe
Oct 23 10:33:57.878 -0400: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 0017.
230d.9612 Reassociated KEY_MGMT[NONE]
| 1 | Oct 23 11:28:34.941 -0400 | Interface Dot11Radio0, Station 0017.2303.0149 Reassociated KEY_MGMT[NONE] | |
| 2 | Oct 23 11:28:34.937 -0400 | Interface Dot11Radio0, Deauthenticating Station 0017.2303.0149 Reason: Sending station has left the BSS | |
| 3 | Oct 23 11:28:30.874 -0400 | Interface Dot11Radio0, Station 0017.230d.9612 Reassociated KEY_MGMT[NONE] | |
| 4 | Oct 23 11:28:30.867 -0400 | Interface Dot11Radio0, Deauthenticating Station 0017.230d.9612 Reason: Sending station has left the BSS | |
| 5 | Oct 23 11:28:28.349 -0400 | Interface Dot11Radio0, Station 0017.2301.abcc Reassociated KEY_MGMT[NONE] | |
| 6 | Oct 23 11:28:27.546 -0400 | Interface Dot11Radio0, Deauthenticating Station 0017.23a4.48f5 Reason: Sending station has left the BSS | |
| 7 | Oct 23 11:28:26.944 -0400 | Interface Dot11Radio0, Station MX7 0017.2303.0109 Reassociated KEY_MGMT[NONE] | |
| 8 | Oct 23 11:28:26.940 -0400 | Interface Dot11Radio0, Deauthenticating Station 0017.2303.0109 Reason: Sending station has left the BSS | |
| 9 | Oct 23 11:28:23.483 -0400 | Interface Dot11Radio0, Deauthenticating Station 0017.23a3.ac6b Reason: Previous authentication no longer valid |
ā10-30-2013 04:18 PM
Hola Cristian,
Veo los logs.. pero estos solo indican que tu cliente de wireless a dejado la red, talvez esta iddle/sleep. Tienes que clarificar mas la situacion para poder ayudarte.
Cual exactamente es el problema? (se te estan cayendo los clientes de wireless frequentemente ? )
Que tipo de clientes tienes ? ( windows, smartphones, MAC ? )
Porfavor postear el show ver y show run de el access point.
Saludos.
ā11-01-2013 12:27 PM
Its a signal issue also you may try disabling the aironet extension.
