01-01-2024 11:27 PM
We are experiencing loss of connection of Barcode devices after migrating wlc AireOS to C9800.
I've tried using only 2.4G, disabling FT, disabling Clean Air, changing session time and idle time but it still doesn't work.
Please help me.
Thanks.
01-01-2024 11:59 PM
What is the firmware of the controller?
What is the model of the APs?
Does the scanner support 5.0 Ghz?
01-02-2024 12:56 AM
Controller firmware 17.6.4
APs model: 2802E
I want to add some more information:
- We have not yet transferred all APs to the new WLC C9800, which means they have the same SSID name on 2 controllers running in parallel.
- Barcode devices are configured with static IP addresses directly on the device
01-02-2024 01:02 AM
>... We have not yet transferred all APs to the new WLC C9800, which means they have the same SSID name on 2 controllers running in parallel.
This is not recommended and may lead to trouble , consider moving to single based WLC C9800 setup ASAP.
M.
01-02-2024 01:41 AM
Are both WLC in the same Wireless Mobility Group?
01-02-2024 01:53 AM
No, we are planning to replace the old WLC AireOS device, and we are experiencing this issue when migrating some APs to the new WLC C9800 for testing.
01-02-2024 02:13 AM
>...- Barcode devices are configured with static IP addresses directly on the device
Added reply ; consider moving to DHCP for wireless clients as it is more common and will work better on C9800 deployments (too)
M,
01-02-2024 12:28 AM
- Debug problematic clients according to https://logadvisor.cisco.com/logadvisor/wireless/9800/9800ClientConnectivity
You can have client debugs (so called RadioActive Traces) analyzed with : https://cway.cisco.com/tools/WirelessDebugAnalyzer/
- Use an advisory software version on the C9800 such as 17.9.4a
- Have a checkup of the C9800 with the CLI command show tech wireless and feed the output into Wireless Config Analyzer
This procedure should be considered mandatory
M.
01-02-2024 01:45 AM
01-02-2024 02:10 AM
>...I've done the debugging and analysis as you instructed, but I still haven't found a solution.
Below you will find the result of the debugTrace when analyzed with Wireless Debug Analyzer
Remember to use the WirelessAnalyzer procedure too as outlined in my initial reply with the CLI command show tech wireless and feed the output into : Wireless Config Analyzer
This is very important!
TimeTaskTranslated
| Connection attempt #1 | |||
| Connection attempt #2 | |||
| 2024/01/02 09:50:35.151 | client-orch-sm | Client made a new Association to an AP/BSSID: BSSID c4b2.39a0.de21, old BSSID bc26.c7aa.b501, WLAN HVN-LET, Slot 0 AP c4b2.39a0.de20, VPC-CAP-R50-AF3T7-213 | |
| 2024/01/02 09:50:35.152 | dot11 | Association success for client, assigned AID is: 1 | |
| 2024/01/02 09:50:35.152 | client-orch-sm | Client started layer 2 authentication (either dot1X or PSK) | |
| 2024/01/02 09:50:35.178 | client-keymgmt | Sent M1 for EAPOL 4-Way Handshake | |
| 2024/01/02 09:50:35.276 | client-keymgmt | Received and validated M2 for EAPOL 4-Way Handshake | |
| 2024/01/02 09:50:35.277 | client-keymgmt | Sent M3 for EAPOL 4-Way Handshake | |
| 2024/01/02 09:50:35.281 | client-keymgmt | Received and validated M4 for EAPOL 4-Way Handshake | |
| 2024/01/02 09:50:35.281 | client-keymgmt | Negotiated the following encryption mechanism: AKM:PSK Cipher:CCMP WPA Version: WPA2 | |
| 2024/01/02 09:50:35.282 | client-auth | Client successfully completed Pre-shared Key authentication. Assigned VLAN: 29 | |
| 2024/01/02 09:50:35.282 | client-orch-sm | Client passed layer 2 authentication | |
| 2024/01/02 09:50:35.282 | client-orch-state | Starting Mobility Anchor discovery for client | |
| 2024/01/02 09:50:35.282 | client-orch-state | Entering IP learn state | |
| 2024/01/02 09:50:35.283 | client-orch-sm | IP Learn state completed, IP information discovered through: IPLEARN_METHOD_ARP | |
| 2024/01/02 09:50:35.283 | client-orch-state | Client reached RUN state, connection completed. | |
| 2024/01/02 09:50:35.826 | client-iplearn | ||
| 2024/01/02 09:50:35.827 | client-iplearn | ||
| 2024/01/02 09:53:29.153 | client-orch-sm | Controller initiated client deletion with code: CO_CLIENT_DELETE_REASON_BSSID_DOWN. Explanation: Triggered by configuration changes, for example WLAN or Policy profile modifications. Actions: None required | |
| 2024/01/02 09:53:29.154 | dot11 | Disassociation packet sent with code status: 252, interpretation: Multiple triggers | |
| Connection attempt #3 | |||
| 2024/01/02 09:53:49.155 | client-orch-sm | Client made a new Association to an AP/BSSID: BSSID bc26.c7aa.b501, WLAN HVN-LET, Slot 0 AP bc26.c7aa.b500, VPC2-CAP-R55-AEAF2-93 | |
| 2024/01/02 09:53:49.156 | dot11 | Association success for client, assigned AID is: 25 | |
| 2024/01/02 09:53:49.156 | client-orch-sm | Client started layer 2 authentication (either dot1X or PSK) | |
| 2024/01/02 09:53:49.161 | client-keymgmt | Sent M1 for EAPOL 4-Way Handshake | |
| 2024/01/02 09:53:49.165 | client-keymgmt | Received and validated M2 for EAPOL 4-Way Handshake | |
| 2024/01/02 09:53:49.165 | client-keymgmt | Sent M3 for EAPOL 4-Way Handshake | |
| 2024/01/02 09:53:49.169 | client-keymgmt | Received and validated M4 for EAPOL 4-Way Handshake | |
| 2024/01/02 09:53:49.169 | client-keymgmt | Negotiated the following encryption mechanism: AKM:PSK Cipher:CCMP WPA Version: WPA2 | |
| 2024/01/02 09:53:49.169 | client-auth | Client successfully completed Pre-shared Key authentication. Assigned VLAN: 29 | |
| 2024/01/02 09:53:49.169 | client-orch-sm | Client passed layer 2 authentication | |
| 2024/01/02 09:53:49.169 | client-orch-state | Starting Mobility Anchor discovery for client | |
| 2024/01/02 09:53:49.171 | client-orch-state | Entering IP learn state | |
| 2024/01/02 09:53:49.724 | client-iplearn | ||
| 2024/01/02 09:53:49.726 | client-iplearn | ||
| 2024/01/02 09:55:49.171 | client-orch-sm | Controller initiated client deletion with code: CO_CLIENT_DELETE_REASON_IPLEARN_CONNECT_TIMEOUT. Explanation: Controller did not learn client IP address in the allowed time. Actions: Check DHCP server and client IP configuration. Validate if DHCP required is set and client is performing DHCP negotiation. If all is correct, collect RA traces and EPC | |
| 2024/01/02 09:55:49.172 | dot11 | Disassociation packet sent with code status: 108 | |
01-02-2024 02:39 AM
I migrated the APs back to the old WLC AireOS system.
Can I still Show tech wireless on the new WLC C9800 to get information or does it have to have APs and Clients?
01-02-2024 02:48 AM
>....Can I still Show tech wireless on the new WLC C9800 to get information or does it have to have APs and Clients?
- Yes , it is always good practice to use the mentioned WirelessAnalyzer procedure with show tech wireless , before production use of the C9800 , (can be used without APs and clients perfectly)
M.
01-02-2024 02:41 AM
As I added above, Barcode devices are configured with static IP addresses directly on the device, we don't use DHCP for them
01-02-2024 07:58 PM
Can you tell me more about the behavior of the WLC upgrade process?
As far as I know the APs will upgrade to the same version of WLC, but I don't know when it will do that and will it have to be reboot?
Are there any risks, for example, that it will not rejoin the WLC?
Thank you.
01-02-2024 08:32 PM
>...but I don't know when it will do that and will it have to be reboot?
>...Are there any risks, for example, that it will not rejoin the WLC?
- The whole process is steered by the controller upgrade process and there are no risks for a joining failure after an upgrade in normal circumstances ; check the status of the APs after the upgrade according to :
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/217738-monitor-catalyst-9800-kpis-key-performa.html#anc4
- There are special features available for a smooth AP upgrade sequence ;
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-9/config-guide/b_wl_17_9_cg/m_predwnld_image_ap_ewlc.html?bookSearch=true
M.
