I have two cisco 3702 access points that are configured the same but one associates during an active ping survey without issue and the other one doesn't. I checked them out side by side and the config is the same. Any idea why one associates and the other doesn't? I am using Ekahau version 8.1.1. I think the issue is somewhere in the access point config but I cant seem to find anything.
Any ideas???
Solved! Go to Solution.
I would remove this "infrastructure-ssid optional" command under SSID configuration.
dot11 ssid 3702eSurvey
Also I cannot see any DHCP configuration on your non-working AP. Below available on your working AP
no ip domain lookup
ip domain name lmco.survey
ip dhcp excluded-address 192.168.11.1 192.168.11.100
ip dhcp excluded-address 192.168.11.200 192.168.11.254
ip dhcp pool survey
network 192.168.11.0 255.255.255.0
default-router 192.168.11.10
Rasika
*** Pls rate all useful responses ***
simply type the below on AP CLI.
conf t
no infrastructure-ssid optional
exit
no ip domain lookup
ip dhcp pool survey
end
wr mem
Rasika
without looking AP config how can we advice.
Pls attach two AP configs to have a look
Rasika
You trying to survey with both AP's up at the same time? If so, that might be the issue you are facing. If you just try to power up the one AP that isn't working, you will not get DHCP, so you will have to configure a static address. Are you able to connect and ping the AP then? Just trying to understand exactly what you are trying to do. Also, have you tried to used the working configuration on the non-working one and just changing the hostname and ip address of the AP?
-Scott
No, I am using them separately (one is powered off). I can ping and gui into the non-working one without issue
no ip domain lookup
ip dhcp pool survey
Rasika
Thanks for the sugguestions. I'm not that familar with the CLI commands to make the suggested changes. Can you help with the commands
conf t
exit
no ip domain lookup
ip dhcp pool survey
end
wr mem
Rasika
Thank you for your help. Your sugguestions did the trick
Glad to hear that, thanks for rating as well.
