Trouble with ACS
borysl
Hi I'm a student who is trying figure out how to configure Woreless Network to an internetwork. What would be the proper steps to implement such a network in a two floor facility that is 344sq.ft? We have downloaded the ACS from the web and we are using one base station: Aironet 350. Need Help in setting up a NAS? Thank you, any info would be very appreciateive.
bwalchez
Level 4
Level 4
Generally, you’ll want an access point on each floor but one will work with reduced signal strength. The config is pretty straight-forward from the configuration guide and the NICs are available both PCI and PCMCIA. http://www.cisco.com/pcgi-bin/Support/PSP/psp_view.pl?p=Hardware:Cisco_Aironet_350&s=Documentation#Product_Documentation If you are using and ACS to authenticate your wireless users, set that part up after you’ve established wireless connectivity. Usually, WEP encryption is enough unless you must authenticate your users for some reason
