09-24-2018 07:42 AM - edited 07-05-2021 09:13 AM
I can not change the channel width of radio 5 Ghz to 40 Mhz and 80 Mhz because show gray. please see as attached picture.
Solved! Go to Solution.
09-24-2018 08:15 AM
Hi, it is a while since I did anything with mobility express. But if you change the channel from automatic to static if I remember correctly the width option becomes available.
09-24-2018 07:52 AM
09-24-2018 08:15 AM
09-24-2018 03:11 PM
