upgrade APSP and APDP
komiks
If you upgrade wlc IOS software, does the APSP and APDP will be upgraded, or do you need to upgrade it separately?
Also, what is the difference between APSP and APDP?
2 Accepted Solutions
Mark Elsen
 - Ref : https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/config-guide/b_wl_16_10_cg/software-maintenance-upgrade.html#id_87560
        >...APSP: AP bug fixes, PSIRTs, or minor features that do not require any controller changes.
            APDP: Support for new AP models without introduction of new hardware or software capabilities.
  - These are addons for a specific release (if needed) and must be added and or installed manually ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Leo Laohoo
No.  APDP is aimed at the WLC.  APSP is aimed at the AP.
APSP will cause the APs to reboot.
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Leo Laohoo
when converting an AP from aireos what image do I need to download?
JPavonM
AP will autodownload the image from WLC for that model (only if the AireOS AP is from model x700/x800 series) so you don't have to be concerned about that.
Usually APSP are addressed to COS-APs.
