11-18-2014 05:37 AM - edited 07-05-2021 01:57 AM
The running config is:
- Two WLC5508's in HA SSO setup running version 7.5.102.0
- about 130 x 2602i APs
I need to upgrade to 7.6.130.0 using the pre-download feature to minimize the network downtime.
Is it possible to transfer the 7.6 to the controllers and pre-download 7.6 to all APs, then do the FUS 1.9 upgrade and finally start the actual controller upgrade to 7.6.
So the steps would be:
1. Transfer 7.6 image to primary controller (do not reboot!), so still running 7.4 as active image.
2. Start pre-download of 7.6 image to all APs and wait till all APs have the new image (do not know how long it takes for 130 APs).
3. Upgrade both controllers with FUS 1.9 (HA should upgrade both controllers automatically) (takes about 45 minutes?)
4. Make 7.6 image the active/primary image on controllers and APs and reset controllers.
If the steps above will not work, I would need to upgrade FUS 1.9 which means 1 hour downtime and then start the pre-download to all APs. The pre-download can take a long time I heard, so I need to wait and wait before I can start the 7.6 upgrade, which means another 1 hour downtime.
This way I need two maintenance windows instead of one. So would it be possible to combine the pre-download and FUS?
Bjorn
11-18-2014 05:44 AM
The v7.6 image and the FUS is a separate download and reboot. You need to download v7.6.130.0 and then wait for the primary to transfer it to the secondary. After this, you can do a pre-download then a reboot. The FUS will be the same way as it is a separate download. This is the con of AP SSO enabled.
Scott
11-18-2014 06:55 AM
Scott,
Do I need to upgrade the FUS 1.9 before the 7.6 image or can I do the FUS afterwards? If I can do it afterwards, I can do the upgrades in the same maintenance window. This way I can start the pre-download the day before, so I am pretty sure the APs have the image at the time of the maintenance window.
I cannot find any remarks about the required order of installation (FUS -> image or image -> FUS).
Bjorn
11-19-2014 04:38 AM
Release Notes for Wireless LAN Controller Field Upgrade Software for Release 1.9.0.0 - p2 :
* This release of the Field Upgrade Software is applicable to CISCO WLC's that are installed with the controller software release 6.0 and later.
So strict reading implies that you have to run 7.6 first.
M.
