01-23-2014 06:25 AM - edited 07-05-2021 12:02 AM
Has anyone did an upgrade (from 7.3.112.0) to 7.6?
Has anyone experienced problems with version 7.6? If so, what version do you recommend?
Solved! Go to Solution.
01-27-2014 04:07 AM
HI Mathiew,
Again I will tell that 3700 AP only support atleast 7.6.100.0 version.
Either you can upgarde to this version or you must wait for new release or maintainance relase.
Dont forget to rate helpful posts
01-27-2014 08:12 AM
Stick with v7.4 since you don't have any 3700's.... wait and look at other posting to see if an newer version of 7.6 has issues or not. The lateset doesn't mean the greatest.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
05-12-2014 05:28 AM
Is it possible to use FUS 1.9 for the upgrade to 7.4? Or should I stay with 1.7?
05-12-2014 03:45 PM
Yes. It is possible and good practice.
