Highlighted
Beginner
Upgradeing WLC from 5508 to 9800 - How to move ssid groups to Tag´s
We are about to move our AP´S from 5508 WLC to new 9800-40 WLC.
I use Cisco prime 3.7 to administrat the accesspoints. (about 900)
Is there a way to  add  TAGS in cisco prime to the accesspoints
I used Templates / Lightweight Access Points but there is no way to choose Site Tag Name, RF Tag Name, Policy Tag Name.
I cant add TAGS in the AP config view. Iconfiguration  after the AP moved to new WLC the AP Group Name filed is missing .
2 REPLIES 2
Highlighted
VIP Rising star
Here is the Prime user guide that does mention tags
https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-6/user/guide/bk_CiscoPrimeInfrastructure_3_6_0_UserGuide/bk_CiscoPrimeInfrastructure_3_6_0_UserGuide_chapter_011010.html
From what I can tell it doesn't allow you to manage site tags once the AP has joined the WLC.
I know the 9800 is better being managed with DNA-C
The other option you could look at is the 9800 is able to deploy everything via APIs so you could look at using the APIs to do this.
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Highlighted
I found a way
CONFIGURATION TAGS & PROFILES/ TAGS/AP / STATIC
I can preload a csv file and when the AP register to WLC it gets the right Groups/Tags.
AP MAC Address,Policy Tag Name,Site Tag Name,RF Tag Name
It´s the same as if the ap register to WLC and i config the Group under Edit AP.
