Hi everybody!
I have the following problem.
The schema is:
BR4--------BR3------BR2-------BR1
Where ---- is the wireless link.
BR4 need to communicate with the BR1 lan.
How can I affect the role to the different BR1310? Indeed, i decided to put the BR3 and the BR1 in ROOT Mode but what about the BR2 because it cannot associate to 2 ROOT BRidge ????
Is the only solution is to install an other BRidge with an other antenna and linked with the BR2 with it ethernet port ?
Thanks for your help.
