Steve Chapman
Beginner
Vertical mount 3602e antenna position
When mounting 3602E vertical should all the dual antenna point in one direction (ie all up, all down or 2 up and 2 down?)
Steve
1 ACCEPTED SOLUTION
Scott Fella
Hall of Fame Guru
As long as they are vertical you are fine.
-Scott
5 REPLIES 5
Scott Fella
Hall of Fame Guru
-Scott
I'd keep them all in the same direction, that way you don't have polarity issues.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Leo Laohoo
VIP Community Legend
Antennas should be pointing towards the client or the floor.
david-collins
Beginner
What about a design where 3602e's are mounted on a 30 foot high ceiling and the intent is to use 9 or 10 APs (for high density user senarios) and focus coverage downward in a smaller cell, column-like field?  Would that call for different antenna positions?
30 foot high makes it a challenge to service the ap .. keep that in mind
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
Content for Community-Ad
