I have a PC that connects :
- When connecting to wired LAN boots normally : 2 min max
- When connecting to Wireless LAN, the PC may take 20 min booting (before even openning the session and bringing the VPN tunnel).
I have trace the boot phase on our wireless LAN. It seems :
- The PC-client when booting sends some requests (DNS, LDAP, Win Domain controllers request etc.).
- The WiFi connection is not up, neither the VPN. Hence DNS server responds with « unresolved adress » which is normal. The answer is « 1.1.1.1 » = SESM DNS proxy, which allows to modify unresolved DNS queries with a bogus IP address (set to 1.1.1.1).
- The problem is that the PC-client starts sending requets to « 1.1.1.1 » on some ports particulrly UDP 58, 108, 100, 150, 62, 112..46
- Hence the PC takes 20 min to boot.
- I Have change the PC, then the AP, then the hotspot : same problem !
Does any one have any idea please.
