View AVC and P2P Blocks on 5520 WLC
dan hale
Level 3
Level 3
Hi All,
I have a Cisco WLC 5520 with AVC and P2P enabled to block certain applications. My issues are a wireless client can't ping or remote desktop to another client in the same WLAN which is in the same subnet.
I suspect that the AVC or access list on the WLC is preventing this.
How can I see the specifics of what the ACL or AVC is blocking or can I drill down by the client by debugging or on the GUI to see my suspicion?
I tried debugging the client but, did not see anything specific.
Dan
Sandeep Choudhary
How is the P2P configured: disabledrop ?
Dont forget to rate helpful posts
Scott Fella
The easiest way is to remove what you have and then add one thing at a time. This is easily achieved by creating a new ssid that you can test with. P2P is probably the issue, but again, test and slowly eliminate variables and figure out what you need and don’t need.
-Scott
