VLAN 1 for SSID on AP C9120AX, VLAN ID 1 AS CLIENT VLAN
Arthur Morgan
Hi Community,
I have a C9120AX system with C9120AX EWC, Firmware Version 17.12.04
I have VLAN 100 for Manage AP and Controller, and VLAN 10 and VLAN 1 For SSID
This is my configuration:
- on Switch:
Description ap
switchport mode trunk
switchport trunk native vlan 100
switchport trunk allow VLAN 1,10,100
- On flex-Profile I NATIVE VLAN 100, Create VLAN 1, VLAN 10
On Policy Profile-was tagged to my Guest SSID, PS: i was try to enter "1" in field (Picture below)
- ISSUE: VLAN 10 is Working good with my Client, but VLAN 1 doesn't Work for my Client
Im i doing anything wrong, pls help me
Thanks and best regards,
7 Replies 7
Scott Fella
Vlan 1 is typically not tagged, so that is similar to native vlan on a trunk port. If you create another vlan that is tagged, that would work, but not vlan 1.
-Scott
Hi, Scott
For you Information, i have known this because old wireless System (Aironet 2800 WLC) can run VLAN 1 on an Native VLAN port, btw i cap this picture (below) when i try to enter VLAN 1 on Policy Profile for Guest (C9120ewc)
hope i guest an way to configure the same on C9120ewc
thanks,
So since you have experience with the Aironet gear, put the AP on vlan 1 and the guest said will work.
-Scott
hi Scott,
I am deploying new wireless system(c9120ax) according to old wireless system (Air2800), but i can't make VLAN 1 for Client work on new system, i find the way to make it work with new system, the information above is what all i know
thank you for your information, best regards
marce1000
 - Try to avoid VLAN1 for wireless purposes (SSID/WLAN/Client Vlan) ; use another vlan
 M.
Hi Marce,
I can make any changes for system, so i have to configure exact old system, because both Old and New system are working at the same time
thanks for advice, i will keep it in mind
srimal99
As @marce1000 try with different vlan. See some previous threads regarding vlan 1
Solved: New Cisco EWC deployment and I cannot drop traffic on vlan1 - Cisco Community
