vWLC license not work
teru-lei
                   Hi All,
I tried to install my permanent license of my vWLC running 7.5 version and I change the priority of the eval license from high to low in order to make the pernament (base-ap-count) license to status "In-Used". However, after the vWLC reboot the supported AP number is reset to zero although I checked the license is still there. I found there is license error when the vWLC boot up as attached image and I tried to search internet and Cisco website for answer but in vain. Does anybody know how to make it work?
Thanks.
Best Regards,
Teru Lei
Scott Fella
You need to open a TAC case with licensing.
-Scott
a.gesse
Hi Teru
could you check if current s/n of the vWLC is the same as one in the license file (filename)?
I have experience when s/n changes after reboot even if vm id stays same.
Alexander
