05-27-2006 12:54 PM - edited 07-04-2021 12:11 PM
Could anyone point me to some documentation on supported Wall-mount patch antenna for the HWIC-AP-G-E card?
I found this one "AIR-ANT3549", but it seems to have been EOL announced.
Any help appricieted.
05-27-2006 07:23 PM
Hi Teddy,
Have you looked at these docs?
ANTENNAS
A pair of removable RP-TNC Swivel-mount Omnidirectional Dipole antennas included with the HWICs provides adequate range and coverage for most wireless installations. A variety of non-captive single band Cisco 2.4 GHz and multiband 2.4/5 GHz antennas are available as options to accommodate wireless installation-specific range and coverage requirements.
2.4 GHz Single Band Access Point Antenna Options for the 802.11 B/G Access Point HWIC
AIR-ANT2422D-R
2.2 dBi Cisco Aironet 2.4 GHz Swivel mount dipole (system part number for AIR-ANT4941 spare)
AIR-ANT4941
2.2 dBi Cisco Aironet 2.4 GHz Swivel mount dipole, spare
AIR-ANT2420V-R
2 dBi Cisco Aironet 2.4 GHz Diversity omni-directional ceiling mount patch (system part number for AIR-ANT5959 spare)
AIR-ANT5959
2 dBi Cisco Aironet 2.4 GHz Diversity omni-directional ceiling mount patch, spare
AIR-ANT1728
5.2 dBi Cisco Aironet 2.4 GHz Omni-directional ceiling mount, spare
AIR-ANT3549
9.0 dBi Cisco Aironet 2.4 GHz Wall-mount patch antenna, spare (not supported for US/Canada)
2.4/5 GHz Dual Band Access Point Antenna Options for the 802.11 A/B/G Access Point HWIC
AIR-ANTM2050D-R
(2.2 dBi Cisco 2.4 Ghz and 5.0 dBi 5 GHz) Dual band Swivel mount dipole antenna
AIR-ANTM2050D-R=
(2.2 dBi Cisco 2.4 Ghz and 5.0 dBi 5 GHz) Dual band Swivel mount dipole antenna, spare
AIR-ANTM5560P-R
(5.5 dBi Cisco 2.4 Ghz and 6.0 dBi 5 GHz) Dual band Wall-mount patch antenna
AIR-ANTM5560P-R=
(5.5 dBi Cisco 2.4 Ghz and 6.0 dBi 5 GHz) Dual band Wall-mount patch antenna, spare
AIR-ANTM4050V-R
(4.0 dBi Cisco 2.4 Ghz and 5.0 dBi 5 GHz) Dual band Diversity Ceiling-mount omnidirectional antenna
AIR-ANTM4050V-R=
(4.0 dBi Cisco 2.4Ghz and 5.0 dBi 5GHz) Dual band Diversity Ceiling-mount omnidirectional antenna, spare
From this doc;
http://www.cisco.com/en/US/products/ps5949/products_data_sheet0900aecd8028cc7b.html
Have you checked out this guide;
Cisco Aironet Antenna Reference Guide
http://www.cisco.com/en/US/products/hw/wireless/ps469/products_data_sheet09186a008008883b.html
Are you looking for a wall mount patch just for aesthetics? We have had really good luck with the 5959 ceiling mount patch, but in many cases we have actually attached it to the wall. It is pretty "low profile" and blends in quite nicely.
Hope this helps!
Rob
Please remember to rate helpful posts.........
06-01-2006 08:17 AM
Sorry I havn't had time to answer you before.
Yes, I actually have looked at the docs, I think that is why I got confused.
But I like the idea of using the AIR-ANT5959 as a wall mount antenna, because it is the most neutral looking antenna, that best blends in with the background. And if you say it works fine as a wall mount antenna, I'll go with that.
06-02-2006 05:00 AM
Hey Teddy,
No worries! I know that we are all busy out here. The 5959 comes with about 1M of cable. Hopefully that length will work for you. If not, don't forget to order an extra run of "low loss" cable (comes in various lengths).Let us know how the antenna works for you!
Take care.
Rob
06-05-2006 09:24 AM
Your are thinking of some sort af cable like this AIR-CAB020LL-R, wright?
And don't worry I'll get back when I'm done.
Thanks for helping.
