Wall Mounted Cisco 3500e AP
bobelliot1321
Looking at the Cisco Aironet 3500e. When it is ceiling mounted, all 6 antennas are directed vertically towards the floor. When the AP is wall mounted, I guess the antennas should be adjusted at the hinge joint to be vertical. However, the antennas are longer than the spacing between them which means they can't be oriented directly vertical.
Instead of         |      they're going to look like     |
Is that satisfactory according to installation practice? Can't see away around it unless the access point is rotated by 90 degrees then the antennas can be mounted vertically without colliding with their neighbors.
Thanks very much, Bob
8 Replies 8
