WAP371 APs - deauthentications and disassociations
seventhtiger
Hi all,
My WiFi network suffers from constant deauthentications and disassociations. Sometimes I can't reconnect the laptop until I reboot the AP. Tried what was suggested in other thread which helped the guy but it didn't help me, which was disabling n for 2.4GHz and n/ac for 5GHz, leaving as seen here:
Currently I have there 6x WAP371 and their logs look pretty much the same, that's from one of them:
Log Table
Time StampSeverityServiceDescription
Nov 14 2019 10:23:43debughostapd[4537]station: 2c:61:f6:ba:88:25 deauthenticated
Nov 14 2019 10:23:43infohostapd[4537]STA 2c:61:f6:ba:88:25 disassociated from BSSID 84:8a:8d:f4:1f:b0 reason 8: Sending STA is leaving BSS
Nov 14 2019 10:23:43infohostapd[4537]STA 2c:61:f6:ba:88:25 deauthed from BSSID 84:8a:8d:f4:1f:b0 reason 4: Disassociated due to inactivity
Nov 14 2019 10:21:26infohostapd[4537]STA 2c:61:f6:ba:88:25 associated with BSSID 84:8a:8d:f4:1f:b0
Nov 14 2019 10:21:26infohostapd[4537]Assoc request from 2c:61:f6:ba:88:25 BSSID 84:8a:8d:f4:1f:b0 SSID Project - 5G
Nov 14 2019 10:16:46infohostapd[4537]STA e4:9a:dc:e9:b5:1f associated with BSSID 84:8a:8d:f4:1f:b0
Nov 14 2019 10:16:46infohostapd[4537]Assoc request from e4:9a:dc:e9:b5:1f BSSID 84:8a:8d:f4:1f:b0 SSID Project - 5G
Nov 14 2019 10:16:46errhostapd[4537]trying to deauthenticate to station e4:9a:dc:e9:b5:1f, but not authenticated
Nov 14 2019 10:16:46errhostapd[4537]trying to update accounting statistics, station e4:9a:dc:e9:b5:1f not found
Nov 14 2019 10:16:46infohostapd[4537]STA e4:9a:dc:e9:b5:1f deauthed from BSSID 84:8a:8d:f4:1f:b0 reason 3: STA is leaving IBSS or ESS
Nov 14 2019 10:15:50infohostapd[4537]STA e4:9a:dc:e9:b5:1f deauthenticated for reason 15: 4-way handshake timeout
Nov 14 2019 10:15:50infohostapd[4537]Station e4:9a:dc:e9:b5:1f had an authentication failure, reason 16
Nov 14 2019 10:15:47infohostapd[4537]Station e4:9a:dc:e9:b5:1f had an authentication failure, reason 22
Nov 14 2019 10:15:45infohostapd[4537]Station e4:9a:dc:e9:b5:1f had an authentication failure, reason 22
Nov 14 2019 10:15:44infohostapd[4537]Station e4:9a:dc:e9:b5:1f had an authentication failure, reason 22
Nov 14 2019 10:15:44infohostapd[4537]STA e4:9a:dc:e9:b5:1f associated with BSSID 84:8a:8d:f4:1f:b8
Nov 14 2019 10:15:44infohostapd[4537]Assoc request from e4:9a:dc:e9:b5:1f BSSID 84:8a:8d:f4:1f:b8 SSID Project
Nov 14 2019 10:15:13infohostapd[4537]STA e4:9a:dc:e9:b5:1f deauthenticated for reason 15: 4-way handshake timeout
Nov 14 2019 10:15:13infohostapd[4537]Station e4:9a:dc:e9:b5:1f had an authentication failure, reason 16
Nov 14 2019 10:15:10infohostapd[4537]Station e4:9a:dc:e9:b5:1f had an authentication failure, reason 22
Nov 14 2019 10:15:08infohostapd[4537]Station e4:9a:dc:e9:b5:1f had an authentication failure, reason 22
Nov 14 2019 10:15:07infohostapd[4537]Station e4:9a:dc:e9:b5:1f had an authentication failure, reason 22
Nov 14 2019 10:15:07infohostapd[4537]STA e4:9a:dc:e9:b5:1f associated with BSSID 84:8a:8d:f4:1f:b8
Nov 14 2019 10:15:07infohostapd[4537]Assoc request from e4:9a:dc:e9:b5:1f BSSID 84:8a:8d:f4:1f:b8 SSID Project
Nov 14 2019 10:14:36infohostapd[4537]STA e4:9a:dc:e9:b5:1f deauthenticated for reason 15: 4-way handshake timeout
Nov 14 2019 10:14:36infohostapd[4537]Station e4:9a:dc:e9:b5:1f had an authentication failure, reason 16
Nov 14 2019 10:14:33infohostapd[4537]Station e4:9a:dc:e9:b5:1f had an authentication failure, reason 22
Nov 14 2019 10:14:31infohostapd[4537]Station e4:9a:dc:e9:b5:1f had an authentication failure, reason 22
Nov 14 2019 10:14:30infohostapd[4537]Station e4:9a:dc:e9:b5:1f had an authentication failure, reason 22
Nov 14 2019 10:14:30infohostapd[4537]STA e4:9a:dc:e9:b5:1f associated with BSSID 84:8a:8d:f4:1f:b8
Nov 14 2019 10:14:30infohostapd[4537]Assoc request from e4:9a:dc:e9:b5:1f BSSID 84:8a:8d:f4:1f:b8 SSID Project
Nov 14 2019 10:14:01infohostapd[4537]STA e4:9a:dc:e9:b5:1f deauthenticated for reason 15: 4-way handshake timeout
Nov 14 2019 10:14:01infohostapd[4537]Station e4:9a:dc:e9:b5:1f had an authentication failure, reason 16
Nov 14 2019 10:13:58infohostapd[4537]Station e4:9a:dc:e9:b5:1f had an authentication failure, reason 22
Nov 14 2019 10:13:56infohostapd[4537]Station e4:9a:dc:e9:b5:1f had an authentication failure, reason 22
Nov 14 2019 10:13:55infohostapd[4537]Station e4:9a:dc:e9:b5:1f had an authentication failure, reason 22
Nov 14 2019 10:13:55infohostapd[4537]STA e4:9a:dc:e9:b5:1f associated with BSSID 84:8a:8d:f4:1f:b8
Nov 14 2019 10:13:55infohostapd[4537]Assoc request from e4:9a:dc:e9:b5:1f BSSID 84:8a:8d:f4:1f:b8 SSID Project
Nov 14 2019 10:12:18infohostapd[4537]STA e4:9a:dc:e9:b5:1f deauthenticated for reason 15: 4-way handshake timeout
Nov 14 2019 10:12:18infohostapd[4537]Station e4:9a:dc:e9:b5:1f had an authentication failure, reason 16
Nov 14 2019 10:12:15infohostapd[4537]Station e4:9a:dc:e9:b5:1f had an authentication failure, reason 22
Nov 14 2019 10:12:13infohostapd[4537]Station e4:9a:dc:e9:b5:1f had an authentication failure, reason 22
Nov 14 2019 10:12:12infohostapd[4537]Station e4:9a:dc:e9:b5:1f had an authentication failure, reason 22
This network is essentially combined of the following:
 - 2x Cisco SG350X-24P
 - 2x Ubiquiti NanoStation 5AC (PTP link between the switches/sites)
 - 6x Cisco WAP371 (4 at one site and 2 at the other)
Additional info:
All APs work as Single Point Setup and all are affected, regardless of the site.
DHCP is on HP server (first site with 4 APs).
No issues with Ethernet network at all at both sites.
There are three VLANs configured on switches, APs are using only one of them.
No other WiFi network in the area.
Up to 30 wireless clients in total across all APs.
Wireless clients move their devices only occasionally, rarely.
All firmware up to date.
Help.
seventhtiger
Help. Anyone. Please.
