09-09-2022 04:57 AM
I have a task to be doing Wifi installation in a warehouse.
The warehouse is 100 m x 52 m.
Hight is 12 meter.
The AccessPoints it going to be 2802E, but i cant decided if is best to use omni diretional antennas, or diretional with one in each end of the rows?
09-09-2022 05:37 AM
Get a wireless site survey done correctly.
09-09-2022 05:41 AM
The building is not built yet, but we will need to deciede where to place the AccessPoints, so the cable company know´s where to make network connections.
09-09-2022 06:51 PM - edited 09-09-2022 06:52 PM
"building is not built yet" is just an excuse.
A wireless site survey is also known as a wireless AP placement design. If all the above information is plotted, it will provide a rough indication as to where the APs can be place, what model/antenna combo to use, how high will it have to be positioned.
IMPORTANT: Remember, during this stage the racks are TOTALLY EMPTY.
NOTE: How it will be installed (dangling from a trapeze or bolted to a frame of the rack) is an structural engineer's job.
09-14-2022 08:21 AM
Exactly - you can do a predictive site survey in advance.
09-10-2022 03:35 PM
Watch this recorded session where Mac & Matt give detail explanation a big warehouse they did with Cisco AP/Antenna. You will get a good insight from here
How to design WiFi for a 720k sq. foot Warehouse by WiFi Ninjas
Wall mounts or celling mounts depend mostly on practicality of implementation.
Rasika
***Pls rate all useful responses ***
09-12-2022 01:51 AM
I've done some warehouses like this one and some good antennas to start with will be the Acceltex ATS-OHDP-245-13-4NJ-IC at both sides of the aisles, and the Acceltex ATS-OP-245-13-6RPTP-36 in the middle of the aisles to provide full redundacy with 2 APs along the aisle in case anyone fails in that aisle.
