Warning page on Cisco Wireless Lan Controller for guest access
Amit Sharma
We have an Cisco wireless LAN controller 4400 in our organization, and lots of guest using our Wi-Fi network.
I would like to configure a warning and terms and condition page when guest using first time our network.
Can you please let me know is that possible without adding external web server and how to configure.
Many Thanks in Advance
Amit Sharma
5 Replies 5
Surendra BG
Hi Amit,
Hope you are doing great!!
the below link will help you in getting the issue resolved!!
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a00809bdb5f.shtml
Please dont forget to rate the usefull posts!!
Surendra
Surendra BG
Hi Surendra,
Thanks for your reply, passthrough is not my solution.
In my organization over 500 guest come every day and I can't install Cisco Aironet Desktop Utility in every client laptop.
basically I am just looking the solution that guest can accept term and condition and can continue to internet surfing.
Amit
Cisco ADU is not REQUIRED!! any client works... I dont know ur reqiorements exactly but i have see customer using this feature for more than 1000 users not just 500!!
Surendra
Surendra BG
Hi Surendra,
Thanks again for your reply.
That’s means I don’t need to install Cisco Aironet Desktop Utility?
If not then its brilliant, I can try this
Amit
Yes ur right!! we do not need the ADU as a mandatory component.. we can use any client utility!!
Surendra
Surendra BG
