11-09-2010 06:37 AM - edited 07-03-2021 07:23 PM
So we're setting up our WCS and I am not sure how to set the orientation for the antennae shown below.
I guess my first question would be to ask what the significance of the arrow (left side of the picture below) is? If you see the picture of the antennae on the right (with the 0 degree/up arrow) we have our AP mounted with the Cisco logo facing the floor. That said, question number two would be to see if someone can confirm the value I have set on the left..
It seems to make more sense with the directional antennae, but for the omni's we are slightly confused with the results shown on the floor plan vs degrees set.
Solved! Go to Solution.
11-09-2010 10:10 AM
facing the floor = 90 down.
To confirm this, you can see that 1130 have by default 90 down of elevation and they are meant to be on the ceiling facing the floor.
It's less impacting with an omni but the elevation still has an importance. The omni doesn't have a sphere shape but a kind of oval/egg shape so the elevation will match that. It's the azimuth of the omni which has zero importance at all since that plane is completely round from a coverage pattern.
Nicolas
don't forget to rate answers that you find useful
11-09-2010 10:10 AM
Nicolas
11-09-2010 11:50 AM
Thanks, Nicolas.
