Showing results forĀ
Search instead forĀ
Did you mean:Ā
WCS Heat-MAP
I am using the planning mode available in the WCS to generate proposals, Is there any way that in the proposal I can just view the heatmap and not the AP's. The reason for this is, I just generated the proposal of a mall. As the space is  huge it is requiring minimum 60 AP's . And the view is hindering the whole coverage area. Any help on this issue will be very helpful
0 Replies 0
